Check engine light comes on, runs rough
Old 07-10-2019, 06:31 AM
hickory1991
hickory1991 is online now
hickory1991 is gaining momentum as a positive member of FTE.
Just started to have this problem. Driving along normal engine starts running rough, shuddering and check engine light comes on. I pull over and shut engine off. Let it set for 5 minutes or so and will start and run fine for a week or more. Has done this 4 times in the last month. Thru searching this forum I know there could be many causes. I have no way to pull codes. Any wild guesses as to my problem. 2002 F-250 7.3l crew cab xlt. 212,000 miles. Runs great other than this little problem.
Old 07-10-2019, 08:01 AM
FordTruckNoob's Avatar
FordTruckNoob
FordTruckNoob is online now
A Prairie Home PSD
FordTruckNoob has a good reputation on FTE.FordTruckNoob has a good reputation on FTE.FordTruckNoob has a good reputation on FTE.
Wild guess: check fuel filter and in-tank screens.
Old 07-10-2019, 08:08 AM
seville009
seville009 is offline
seville009 has a good reputation on FTE.seville009 has a good reputation on FTE.seville009 has a good reputation on FTE.
Any auto store will read the codes for you. Thatís the best place to start, as it should point you directly to the issue.
I had a 2006 f350 5.4l that thru a cel and ran real rough. Was a dirty throttle body; cleaned it and ran fine
Old 07-10-2019, 10:29 AM
brian42's Avatar
brian42
brian42 is online now
brian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant futurebrian42 has a brilliant future
Check your UVCH connections to make sure they are not loose.
Also you could have chafing where the engine wire harness (42-pin connector) rubs on the driver's side valve cover...
Old 07-10-2019, 10:31 PM
aawlberninf350's Avatar
aawlberninf350
aawlberninf350 is offline
It's a Van Gogh
aawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud of
First guess same as Brian42s, UVCH rubbing on VC.
Also many generic code readers cannot read these trucks. Maybe the one at the car parts store will work, maybe not. These trucks are not fully OBDII compliant. Android apps like Torque Pro, FORScan and Car Gauge can read them, used along with a blue tooth OBD adapter. Search around for info on them, and pay attention to how current the info is.
Old 07-11-2019, 04:53 AM
hickory1991
Thanks for the tips gentlemen. Hopefully will have time this weekend to check things out.
Old 07-15-2019, 11:28 AM
hickory1991
Had some time this weekend to look into my problem. Turns out I had a little chafing on the 42 pin connector wires on the valve cover as you suggested. A little tape and a short piece of heater hose sliced to fit and protect the wires. So far so good. Thanks for the tip.
Old 07-15-2019, 12:38 PM
brian42's Avatar
brian42
Excellent. Thanks for posting your follow-up.
Glad you found and it was a cheap fix.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
