Thoughts on Leveling and Stock Tire Size
So I need new boots for the nifty F150. Well, actually, I’m going to give my son my Dynapros for the last 20k to replace his Crapinentals, so I need some boots. I’m thinking of leveling and maybe adding a taller rear block sometime, but not right now. I’m curious if stock 275/55R20’s will look out of place after the level/rear lift. I wanted OWL tires, but they are not available unless you get into 34’s with much wider widths. I’m not interested in the mpg hit with big boots. Any pointers from experienced veterans?
In this thread at post #11, you will see a 157” truck leveled with stock 20s
https://www.ford-trucks.com/forums/1...o-measure.html
Does it look bad? No, but kind of off looking. The longer wheelbase makes the tires look even smaller.
You could do a 285/60/20 (33”). A 275/65/20 (34.1”) will fit perfectly on you wheels with a leveling kit. You can buy brand new Super Duty Michelin take offs in that size cheap, as many want AT tires put on when new.
Those tires will fit factory 20” wheels perfect with a 2.25-2.5” leveling kit.
All of the 20” tires that are more than 33” tall will be load range E and will be on the heavy side. Fuel mileage will look bad if you don’t recalibrate the speedometer. Since the larger wheels are turning slower, the truck records less miles between fill ups than actually travelled.
Johndays’s truck above has Raptor wheels and tires on it. Mine has the same. 34.5” tall. Fit’s just right with a 2.25” leveling kit. I wouldn’t go any taller or wider. They are 315/70/17s load range C, so they don’t ride too bad.
My 18” wheels have Toyo 295/70/18s on them. Very heavy tires, E rated but for over 4k lbs each. Once I adjusted the speedometer my MPG was only off about 1.5 or so. I didn’t adjust for the Raptor wheels/tires as they are just about the same height as the Toyos that were on it.
315/70/17 stock Raptor wheels and tires. 34.5” tall
295/70/18 Toyos on stock 18” wheels. 34.3” tall.
JKBrad's ride with the 18's looks the best to my eye.
That's what I think too. I got new 17" wheels for my truck (not on yet) and 285/70R17 tires which are only an inch taller than the stockers, but they look way bigger.
