2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Tire Pressure When NOT Hauling
Old 07-09-2019, 01:50 PM
crmitche
crmitche is offline
crmitche is starting off with a positive reputation.
Recommended tire pressure for my 2019 gas, short bed, crew cab is 60/75 PSI front/rear for 275/65-R18. I'm assume this is based on a fully loaded vehicle. At least 75% of the time we won't be hauling and be a daily driver. Has anyone experimented with lower pressures to smooth the ride out any?
Thanks
Craig
Old 07-09-2019, 01:56 PM
titus_4's Avatar
titus_4
titus_4 is offline
titus_4 is starting off with a positive reputation.
I'm running 55/50 with a CCSB 6.7 used forscan to change the tpms alarms
SDcrewzer's Avatar
SDcrewzer
SDcrewzer is online now
SDcrewzer has a good reputation on FTE.SDcrewzer has a good reputation on FTE.
Our 2019 F350 (details below) t/p specs are 65F and 80R. Lightly loaded, I run ‘em at 55 / 65. The ride is greatly improved, and no TPMS warnings so far.
HTH,
Jim / crewzer
Old 07-09-2019, 02:06 PM
Kaadk
Kaadk is offline
Kaadk is starting off with a positive reputation.
I just run mine at the door sticker's recommendation of 70/75, whether hauling or not. But then again, during camping season it probably sees 60% hauling time, 40% run-around driving, as I don't need to drive to get to work, and I don't want to mess around with constantly airing up/down the tires.
Old 07-09-2019, 02:11 PM
ToMang07's Avatar
ToMang07
ToMang07 is online now
ToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant future
Been wondering about the TPMS issue myself. I've been meaning to air mine down to 55 all around to see how it does. No need for 75psi on the unloaded rear axle. First truck I've owned with these stupid sensors.
Old 07-09-2019, 02:16 PM
H4Racing
H4Racing is offline
H4Racing is gaining momentum as a positive member of FTE.H4Racing is gaining momentum as a positive member of FTE.
60f/65r here when not towing.
Old 07-09-2019, 02:34 PM
Mattm400
Mattm400 is offline
Mattm400 is starting off with a positive reputation.
60 Front, 55 rear, no sensor problems.
Old 07-09-2019, 03:11 PM
NWnative's Avatar
NWnative
NWnative is offline
NWnative is gaining momentum as a positive member of FTE.
60F / 65R on mine.....run it towing and not towing.....rotate tires regularly and have no issues. I don't want to have to mess with the air pressure all the time so just run it at what the sticker says.
Old 07-09-2019, 03:19 PM
N2dunz's Avatar
N2dunz
N2dunz is offline
N2dunz is gaining momentum as a positive member of FTE.
I run 65/35 when not towing. Diesel, crew cab dually.
Old 07-09-2019, 03:31 PM
2019er
2019er is online now
2019er is starting off with a positive reputation.
I air them up to the max, per the door sticker, or near it, at all times regardless. I don't notice it rides that much different. And with the valve stem slow leak, it gives me some buffer before I have to get air again. Going to get that addressed one day soon. It's only 2 tires doing it for now.
Old 07-09-2019, 04:23 PM
DeputyDiesel
DeputyDiesel is offline
DeputyDiesel is starting off with a positive reputation.
50 front 45 rear at operating temperature with Tires that have a 65psi max. There is a quick formula you can use to find the exact pressure you need depending on the inflation load index of your exact tire. You’d need to weight the front and rear of your truck to get it precise. Or do a chalk test as I did and determine the best pressure unloaded.
Old 07-09-2019, 04:26 PM
jbrnigan
jbrnigan is offline
jbrnigan is gaining momentum as a positive member of FTE.
50 psi all around.......Forscan to change tpms alarms
Old 07-09-2019, 04:54 PM
ATC Crazy's Avatar
ATC Crazy
ATC Crazy is offline
ATC Crazy is a splendid one to beholdATC Crazy is a splendid one to beholdATC Crazy is a splendid one to beholdATC Crazy is a splendid one to beholdATC Crazy is a splendid one to beholdATC Crazy is a splendid one to beholdATC Crazy is a splendid one to behold
60 front / 45 rear
I have the smaller OEM tires
Old 07-09-2019, 05:26 PM
2019Platinum
2019Platinum is offline
2019Platinum is starting off with a positive reputation.
60 front 55 rear. No sensor issues.
Old 07-09-2019, 06:59 PM
clc3251
clc3251 is online now
clc3251 is starting off with a positive reputation.
50 all around as well. Greatly improved ride over the factory pressures.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
