Won't start, just cranks
Hutch and Harpoon mods. Search around to decide how you want to do it. Here's a traditional way.
I have a thread here from a few years ago that I listed some parts that I used and followed along with the Guzzle method linked earlier by @aawlberninf350 .
To this day the H/H has been one of my favorite modifications.
Be safe and have fun!
Originally Posted by Scoob5555
ugh. What if I just promise to keep it above 1/4 of a tank forever? If I do that stuff it would have to be after my next cross-country trip in late-August. Hopefully, I don't learn that the fuel pick-up is very broken on that trip...
If the foot did fall off the only drawback is that you no longer have a suction strainer prior to the fuel pump inlet (the fuel pump is located under the cab on the inside of the driver's side frame rail). Couple that with the pieces/parts floating around from the broken pickup foot and there's a risk of getting a chunk into the fuel line that could create blockage or make it's way to the fuel pump and cause even more problems.
It's strictly my opinion but the truck has seen some miles and dropping the tank to inspect it would be as much maintenance as it would troubleshooting. Everything in the tank is ~20 years old and, even if the foot is intact, you can clean any impurities out of the tank and inspect it for any potential issues/damage. Once you see the lay of the land in there you can make a decision on what you want to do.
With the tank down it takes 2 minutes with a $4 PVC cutter from Harbor Freight to clip the filler and vent tubes to gain another 4 gallons of tank capacity (aka Harpoon mod).
Just a thought and my .02. I am but one person and only mentioning what I would do. I will say, though, that my OCD is far above most and nearly on par with Sous.
Sure, but you'll probably want to fix it at some point. Normally the foot just slides onto the upper pickup hose as a friction or compression fit, but it is not the most solid. What I did was get a tiny stainless hose clamp around mine to give it a little extra cinch to keep it in place. And you could clean the two tank screens while at it.
zay1016
30
05-30-2016 09:15 PM
89LX306
10-14-2010 07:40 AM
Pigeon
04-16-2006 05:57 PM
