Exhaust Manifolds blow out
#46
Yes!!! The corrosion was so bad the sockets just slipped with the 6 point. Went to a 9mm with 12 points, that went on a couple, but of course it slipped as well. I would have welcomed the bolts breaking off quite honestly, as long as they weren't flush!
#47
You will find 4 blunt cut wires sticking out if the bundle that runs just below the cowling in the engine bay.
They are for your use so that you don't have to make holes to run things from the cab to the engine bay.
The other ends are in the cab near the e-break assembly. You should also find the PTO and BPTC wires
in that area. The PTO of BPTC are handy if you want to do the high idle mod.
If you want to do this just use the search tool for High Idle Mod.
It kicks the idle up when in park and foot of service brake. This helps warm up and a few other things.
#48
#49
#50
Just a stupid person's guess and remembering where it was, I think it's the glow plug harness. My 18 yo stepson, who is a self proclaimed expert says those are only for winter. Is that correct? Again, it's just a guess based on what I've looked at online and remembering the positioning of the wires.
#51
#52
#53
#54
#55
Ok, here we go. Got the truck completely back together last night, except this wire. This is all the way in the back, under the Y pipe (2nd pic). The "aluminum foil" looking wire is the plug for it. I don't think it has anything to do with glow plugs. But, I do think it has something to do with the truck not starting. Sorry, just uploaded a second pic and it dropped my original pic down. So pics are out of order. So, next question. What is this first picture? When we got the truck back together, it turned over, for 30 seconds or so, but wouldn't start. Then it wouldn't turnover. Batteries are charged. But, whatever this first pic is, it vibrates when just having the key in on position. Not all the time, but I think after the fuel pump shuts off.
#57
#58
#59
#60
