Correct Spindles for Disc Brake Conversion
I'm in the planning stage for doing a disc brake conversion on my '65 F250. I am planning for follow the instructions on the linked article. In the instructions, it says that for the swap on '65-'66 models, the spindle must come from a '74. Is there some reason a spindle from any '73-'79 won't work?
Also, I'm planning to use a disc brake spindle from a F250 so I can keep the 8-lug wheels. Has anyone done this swap with a F250 and found any differences in the procedure? Thanks.
https://www.ford-trucks.com/articles/front-drum-to-disc-brake-conversion-guide-for-1965-1972-ford-trucks/#item1
Stay with the factory stuff so parts are readily available. Here is the guide.
Installing Disc Brakes on Your 2WD Pickup - Pt. 1 - FORDification.com
If you do an advanced search in the 73-79 forum, I'm sure NumberDummy has posted a page form the parts book in the past. If you can't find a parts truck try" Car-Part.com " it is a salvage yard site. I think you may find that the drum brakes you have now are quite good if they are rebuilt and you add a power booster.
bryanA73
08-13-2018 09:49 AM
duane
11-29-1999 09:52 PM
