Forscan vs AE vs TQ Pro for logging
#32
Well, here I am. Have the mx+, down loaded forscan, and read the destructions several times. It won't connect. It says ELM not found try again. Elm is another brand right? I tried numerous times. If its not nails and hammers, or nuts and bolts, this is what happens. I truly am a technotard.
#33
Does the scan tool have lights on it when you plug it into the truck turn the key to on? Is there a small button in the scan tool to make it searchable or able to be seen by searching devices?
#34
#35
I had trouble connecting my MX to Forscan at first too. MX paired up easily to my Windows 10 laptop, all lights were on, but Forscan could not find it. Turns out Forscan saw every Bluetooth device in range and was trying to connect to my cell phone. In Forscan go to the "gear" icon and look at the connections tab. Click on the drop down box for Bluetooth Adapter and choose the one you want. Here's a pic. Hopefully your iOS version of Forscan is similar to the Win 10 version in this way.
#36
ELM is the name of the company that developed the interface between OBDII and PC protocols. To simplify... when you say you're going to "Google" something - you might actually use "Bing". Your app is looking for an "ELM" device to translate the OBDII information. I'm not following the progress so far: Did you pair your device before opening FORScan?
#37
#38
#40
#42
Is this what's needed to work with Forescan on a computer?
https://www.ebay.com/itm/USB-FTDI-Ch...39380beb087914
And not all versions of FORScan are the same, here's a screen cap of their page comparing them. Viewer for iOS is evidently just a viewer, not a doer.
DIYMechanic
175
07-09-2019 09:18 AM
F250_
116
12-05-2018 11:59 PM
