2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Forscan Global Window Up Help
Old 07-07-2019, 05:44 PM
ToMang07's Avatar
ToMang07
ToMang07 is online now
ToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant futureToMang07 has a brilliant future
So going trough the spreadsheet and playing with forscan, I found the GWU sequence. My question is are these number/letter sequences correct? I have never seen Xs in the code, I just feel that's not right.
I haven't changed any code yet because I obviously don't want to brick it.
Old 07-07-2019, 05:50 PM
Rustyfan21
Rustyfan21 is offline
Rustyfan21 is starting off with a positive reputation.
If I'm not mistaken, the x's mean what your current numbers/letters are, you don't change those. Only change the ones listed. I did this to my 17 and works great, ensure that the windows up and down is selected on the menu screen in the gauge cluster.
Old 07-08-2019, 06:56 AM
ToMang07's Avatar
ToMang07
Ok, that makes more sense. I just figured the numbers would be there since they have the before/ after.
Old 07-08-2019, 07:25 AM
Robbgt's Avatar
Robbgt
Robbgt is offline
Robbgt is a splendid one to beholdRobbgt is a splendid one to beholdRobbgt is a splendid one to beholdRobbgt is a splendid one to beholdRobbgt is a splendid one to beholdRobbgt is a splendid one to beholdRobbgt is a splendid one to behold
Before and after for the "X" values could be different for each truck depending on the as-built spec. Registers can also control multiple function - using the "X" allows only the values related to the modification to be defined.
Old 07-08-2019, 09:18 AM
resqpink
resqpink is offline
resqpink is starting off with a positive reputation.
I think I have a different spreadsheet at home- I only changed 1 line to enable mine. And yes, the Xs signify vehicle specific digits that you don't change.
Old 07-09-2019, 07:25 AM
ToMang07's Avatar
ToMang07
You have a copy or link?
Old 07-09-2019, 03:11 PM
ToMang07's Avatar
ToMang07
https://docs.google.com/spreadsheets...it?usp=sharing
I just used the IPC(bottom line for global windows). It added the option to my advanced settings. It works great once turned on there. I figured this way I could turn it off in the future without having to connect forscan again.
Link isn't working
Old 07-09-2019, 03:18 PM
resqpink
resqpink is offline
Try now, it copied differently this time for some reason. It's a workbook with tabs for instructions, etc
Old 07-09-2019, 03:22 PM
resqpink
resqpink is offline
EpicCowlick posted it in a thread on this site. If it doesn't work again do a search for "forscan codes for 2017 super duty".
Old 07-10-2019, 07:17 AM
ToMang07's Avatar
ToMang07
I believe that's the one I have that's edited above, I just wanted to compare.
Old 07-10-2019, 07:19 AM
ToMang07's Avatar
ToMang07
It's working now, looks like it's not the same one. Thanks!
Old 07-11-2019, 09:01 AM
ToMang07's Avatar
ToMang07
Apparently I had the wrong obd2 adapter anyway. Ordered an elm with the mscan switch, hopefully that works.
Old 07-11-2019, 10:16 AM
Flyct
Flyct is offline
Flyct is starting off with a positive reputation.
This is the one I have. It’s not cheap but it works great and no switches to fool with.
https://www.amazon.com/gp/product/B006NZTZLQ/ https://www.amazon.com/gp/product/B006NZTZLQ/
Old 07-11-2019, 12:55 PM
ToMang07's Avatar
ToMang07
I have no issues with the USB ones. I ordered one of the list.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
