64 dash knobs
Old Jul 6, 2019 | 09:51 AM
Mearntain's Avatar
Mearntain
64 dash *****
I've got a 64 F100 and what seemed like should have been a straight forward process, has turned out not to be. I ordered a set of new ***** a while back, I think it was from NPD, and most of them are not working now that I go to put them on.
The only ***** I could successfully replace were the 2 set screw ***** (fan and wiper) along with the lighter ****. All the rest of the ***** given to me are threaded on the inside, but they wont go on the old shafts. The Air ***** when removed do not have threads, but a cross hatch pattern. The Lights **** has an odd thread on it that will not thread onto the ****, ***** hole is too small. Both the air and light old ***** were plastic on the inside, no metal inserts.
Same with my glove box ****, one given to me has a metal insert, current one is just plastic.
On a side note, I'm struggling to remove the old choke ****, any tips?
Where can I source the proper ***** to replace my old ones with?
Old Jul 6, 2019 | 01:27 PM
Mearntain's Avatar
Mearntain
Was just out at the truck and realized all the ***** I have currently are Daniel Carpenter *****. I managed to make the light switch **** work now by running a 3/16 drill bit through the threads, which left enough thread to grab on to the larger diameter rod.
Got the choke **** off and that one also just has the cross hatch, no thread.
Old Jul 6, 2019 | 03:05 PM
AZ66F100's Avatar
AZ66F100
I bought both a choke **** and choke cable from DC last year. You would think they would just fit together, right?
Nope. The **** was threaded, while the cable was not, it had a flat side for a set screw. I just ran new threads on
the cable, so no real problem, but WTH, they can't even get their own products to be compatible???
But once installed, they do look and work fine.
Old Jul 6, 2019 | 04:19 PM
Mearntain's Avatar
Mearntain
My temporary solution for the choke is a friction hold on my **** that I drilled out just enough.
Old Jul 6, 2019 | 04:23 PM
Mearntain's Avatar
Mearntain
I've got most in place so far and they do look good, just need to figure out a solution for my air ***** and glove box ****.
Old Jul 6, 2019 | 05:08 PM
skidoorulz's Avatar
skidoorulz
A little late now but I cleaned all my ***** with a good all purpose cleaner called Speedball by Butchers and a toothbrush. When I was done they looked brand new. All I did was order the white inserts and replaced them.
Old Jul 6, 2019 | 06:42 PM
Mearntain's Avatar
Mearntain
Looks nice! If I cant find a solution for my air ***** and glove box, I may consider going the same route you did.
Old Jul 7, 2019 | 09:02 AM
TA455HO's Avatar
TA455HO
Lead Gopher
The glove box **** is part number
C1TB-8106164-A - **** - INSTRUMENT PANEL GLOVE COMPARTMENT DOOR
A few available NOS at the usual places.
This **** just uses a single screw from behind.
52787-S8 - Screw-pan head, cross recess-No. 10-16 x 1/2"
Old Jul 7, 2019 | 11:46 AM
Mearntain's Avatar
Mearntain
Good stuff. Thanks. I'll pick one up soon. In the meanwhile, I used a threaded "air ****" with a no 6 screw to hold it in place.
Old Jul 8, 2019 | 11:10 AM
SixtyFour's Avatar
SixtyFour
How would one go about removing one of the white **** inlays to replace with a new one? All mine look great except one thats weirdly discolored...
Old Jul 8, 2019 | 11:42 AM
Mearntain's Avatar
Mearntain
I know I tried beating a white insert out of a new **** to try and put it on an old ****, and it wasnt budging at all. I'd think youd probably break the old **** trying to remove it. White inserts cost $3 and ***** with the insert cost about $7-$9, so I'd say just get the whole **** and rig it up like I had to do. Only the set screw ***** were straight forward installations for me.
Old Jul 8, 2019 | 11:44 AM
Mearntain's Avatar
Mearntain
Like I said earlier, I had to rig up all but 3 of them to make DC ***** work, but they're in place, look good, and are functional (atleast for now).
Old Jul 8, 2019 | 11:55 AM
TA455HO's Avatar
TA455HO
Lead Gopher
Looks like someone probably painted at least part of the inside of your cab - I can see the light blue over spray on things like the parking brake handle bracket and the rubber collar on the column bracket. So if you were wanting to color match something with original paint I'm not sure that's the best if it has been repainted. But, it's a known quantity at least.
***** look great. The one on the glove box door would be somewhat shorter than the air ***** or any of the others if you were going for that stocker look.
Old Jul 8, 2019 | 12:56 PM
Mearntain's Avatar
Mearntain
I actually work with the original owners brothers and found out about 2 weeks ago that he did have it repainted at some point in the 80's. I believe it was you that posted a picture of an original skylight blue truck in another thread, and I would say 100% that is a match to my truck. So hopefully when I do repaint the whole thing, I can find someone who can match the color right.
In regards to the dash ****, I'm just using an air handle **** for temporary use. I need to place an order later this week for a couple other parts, and was going to pickup the correct **** at that time too.
Thanks
3twinridges
Aug 28, 2017 09:41 PM
clinkfield
Jul 28, 2013 08:14 PM
deyomatic
Dec 30, 2009 05:39 AM
santi2322
Jan 29, 2009 12:46 PM
erinaldi
Nov 26, 2004 04:24 PM
