99 7.3 lost
Old Jul 5, 2019 | 09:36 PM
albertc's Avatar
albertc
6th Gear
99 7.3 lost
Cracked timing cover replaced replaced oil pan gasket ECT ECT after all said and done started right away found leak under hpop forgot to tighten blew rubber off mounting gasket I think truck sounds terrible is it possible it's because hpop mounting gasket is bad and leaks oil runs down back of oil pan when truck is running nothing when truck is not running I'm believeing the hpop mounting gasket is the problem I reach under to where it sits at timing cover oil on fingers and below also engine sounds bad like no oil does run good also need to check injectors and other engine parts does anyone know how to use forscan using win 10 needing to check everything can anyone Walk me through forscan cyncan61@gmail.com
Old Jul 6, 2019 | 01:46 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Oil running down the back of the engine is pretty much where it usually goes, regardless where it starts from. Clean valley and tuck paper towels under hpop and pedestal to isolate the origin. If hpop yeah, I bet that gasket needs to be replaced.
Say more about replacing oil pan gasket. Recommended way is pull engine, turn over, clean surgically, apply super special grey RTV under sanctified method and timing, smudge sage and pray.
It can take 50 miles or so to clear air out of the oil system after a big job like that.
FORScan and windows 10 don't always pay nice, as I discovered today. Can pair up but Win being stupid about passcodes. Try Android version of FORScan, works as advertised. Or Torque Pro.
Feo
Feb 26, 2011 01:30 PM
dharma_bhum
Aug 8, 2009 03:45 AM
mike L
May 11, 2008 12:36 PM
mike L
Oct 24, 2007 01:29 PM
FordPerf300
Jul 23, 2002 01:45 PM
