2001 f250 7.3 up pipes and pms
Old 07-04-2019, 05:18 PM
KubotaOrange76's Avatar
KubotaOrange76
KubotaOrange76 is offline
KubotaOrange76 is a splendid one to beholdKubotaOrange76 is a splendid one to beholdKubotaOrange76 is a splendid one to beholdKubotaOrange76 is a splendid one to beholdKubotaOrange76 is a splendid one to beholdKubotaOrange76 is a splendid one to behold
Had the truck about a month
168k
decided to do bellowed up pipes(leaking bad). Turbo pedestal rings (leaking bad)
as well as fuel bowl and hpop orings, alternator tensioner idler pulley harnesses glow plugs vc gaskets and a few other misc items too like cps etc
here yall go
first day or progress
Old 07-04-2019, 05:24 PM
KubotaOrange76
Old 07-04-2019, 05:25 PM
KubotaOrange76
Got the up pipes off as well as changed trans and tcase vent hoses
headed to go see fireworks
happy 4th
Old 07-04-2019, 06:13 PM
Colorado350's Avatar
Colorado350
Colorado350 is online now
Colorado350 has much to be proud ofColorado350 has much to be proud ofColorado350 has much to be proud ofColorado350 has much to be proud ofColorado350 has much to be proud ofColorado350 has much to be proud ofColorado350 has much to be proud ofColorado350 has much to be proud of
Ok, taking the cab off is cheating! .
Old 07-04-2019, 06:49 PM
twg1966's Avatar
twg1966
twg1966 is offline
Trying to Gain Knowledge
twg1966 is a name known to alltwg1966 is a name known to alltwg1966 is a name known to alltwg1966 is a name known to alltwg1966 is a name known to alltwg1966 is a name known to all
I need to get a lift so I can use it like that.
Old 07-04-2019, 07:12 PM
KubotaOrange76
I wouldnt call it cheating, just dont want to be bent over anymore Bought it used for $1800 out of a shop
its been amazing
took about 20 mins to pull turbo and another 20 for the up pipes including having to get creative creative with one of the bolts
Old 07-04-2019, 10:52 PM
timmyboy76's Avatar
timmyboy76
timmyboy76 is offline
timmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud of
Haha..thats 1 way to go about it.
Besides the cab bolts, you gotta list from memory on what all needs removed/disconnected to go that route?
Old 07-05-2019, 08:08 AM
ZachinCO's Avatar
ZachinCO
ZachinCO is offline
ZachinCO is gaining momentum as a positive member of FTE.
I guess that's one way of doing it...
Old 07-05-2019, 08:17 AM
MiamiPSD's Avatar
MiamiPSD
MiamiPSD is online now
MiamiPSD is starting off with a positive reputation.
Your shop is too clean and organized. By the looks of things, this isn’t your first rodeo getting cabs off. Great job and yes a detailed list of things to do for cab removal would be great.
Old 07-05-2019, 10:21 AM
KubotaOrange76
HAHA Its cluttered right now. REady to get this done and move back to building the motor for my 79. Got some heads to finish porting and slap the 460 together.
Actually this is my first time raising cab on a newer vehicle. Took about 3 hours, i bet i could do it in two now.
I have done cab swaps on older trucks, but not near as involved.
I compiled this list to follow before hand from a few forums and put into a word doc.
Pretty much everything is correct, except some of the fittings for the trans cooler lines and i was able to leave the PS cooler on just disconnected the hoses.
I also removed the two brake lines that go into the abs controller, and unbolted the controller's three bolts and set it up and over onto the frame. It has braided flex hoses to enable this.
Surprisingly that was the only thing i missed when i started inching it up.
I also marked the floor at the tires, so i hope putting it back together tomorrow isnt too difficult.
Headed home from work now, time to pick up coolant, brake fluid, trans fluid, thermostat, and some misc shop supplies.
Wish me luck on the oil cooler seals, fuel bowl and hpop reseal today. Ill take pics.
File Type: doc
Old 07-05-2019, 06:07 PM
KubotaOrange76
Got started about 4
went ahead and changed tcase fluid
drained oil and put in my old ford tractor and bottled up the old antofreeze to use in my old trucks so that took a little time
finally got to yank the oil cooler
drained oil and drained coolant from block first
came apart cleaned and went back together pretty easy. Green orings broke coming off so Definitely glad i changed them
next came the fuel bowl, ran into snag cause mud dobber decided to make a nest in drain hose. Got the bowl pulled and on the bench.
about to grab a bite to eat then its time to do the hpop then get to resealing.
after that its on to cps, valve covers glowplugs then put it all back together with new up pipes and alternator.
Enjoy
Old 07-05-2019, 08:09 PM
crop harvester
crop harvester is offline
crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.crop harvester has a very good reputation on FTE.
Good Job taking advantage of the extra room for all that maintenance,removing the cab has to be nice.
Old 07-06-2019, 01:32 AM
aawlberninf350's Avatar
aawlberninf350
aawlberninf350 is offline
It's a Van Gogh
aawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud of
What T case fluid? That's been a hot topic.
Recommend Riff Raff intake plenum inserts and set of IC boots plus clamps. Just in case you have more boost later.
If fuel bowl heater is original get the new updated version. Aside from the S&B it looks pretty stock. And consider disconnecting it entirely since you're in Jawja.
What up pipes did you choose? If Dorman suggest dry fit on bench since they can be sketchy. Certainly were sketchy for me!
Hutch and Harpoon mods are almost mandatory, especially when you can lift the bed.
Check power steering line where it passes the shock tower, can rub and leak. Suggest new since they can pop the seal at the PS pump too.
Old 07-06-2019, 08:20 AM
KubotaOrange76
I just went back with mercon 3 for tcase
not oaying that big $ for the new spec
will it explode?
This truck is staying stock. Actually going to put a stock intake back on it if someone wants the s&b
boots and everything still look and feel good plan to stick with what i have just cleaned them up good
deleting the fuel bowl heater.
also going to try and seal off the ebpv actuator . Ill probably regret it later. Anyone evert succesfully done this? It already had the banks elbow and plug for connector.
the up pipes arent china as tempting as it was i went with xdp i think it was?
anyone have a clean link to hutch and harpoon mods? I think the last time i read up in them was 2002 on ford-diesel.com lol
being on a budget sucks
having to fight back temptation to replace all the power steering lines and pump etc . If money were no object it wiuld be a turbo hpop etc etc
all the lines and orings are in great shape. I plan to run them till the pump goes out and then replace it all together.
thank you for the tips
Old 07-06-2019, 08:39 AM
KubotaOrange76
Thinking about gutting actuator and tapping for a brass pipe plug?? Anyone ever done this?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
