2001 f250 7.3 up pipes and pms
  #46
Old 07-12-2019, 09:21 AM
timmyboy76's Avatar
timmyboy76
timmyboy76 is offline
timmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud oftimmyboy76 has much to be proud of
The cv's are under the fittings, insude the hpop. Just a little spring with a flat disk attached to it.
  #47
Old 07-12-2019, 09:44 AM
KubotaOrange76's Avatar
KubotaOrange76
KubotaOrange76 is offline
KubotaOrange76 is a splendid one to beholdKubotaOrange76 is a splendid one to beholdKubotaOrange76 is a splendid one to beholdKubotaOrange76 is a splendid one to beholdKubotaOrange76 is a splendid one to beholdKubotaOrange76 is a splendid one to behold
Thankyou
i removed those to clean the threads before reinstalled them and fittings
  #48
Old 07-12-2019, 05:41 PM
Walleye Hunter
Walleye Hunter is offline
Walleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to beholdWalleye Hunter is a splendid one to behold
And you know the torque on the HPOP fittings is real low, I beilieve it's 25 ft lbs but double check that and use green locitite to hold them in. They do strip easily.
  #49
Old 07-12-2019, 08:00 PM
KubotaOrange76
Thank you
i used the green that came with kit
i commend you guys that have done up pipes cab on , wow
  #50
Old 07-12-2019, 08:45 PM
Walleye Hunter
That pedastal job was that easy? There has to be more to it than that. And add the corrosion of the north to my up pipe job, that was one of the worst jobs I've had to tackle.
  #51
timmyboy76's Avatar
timmyboy76
What exhaust outlet is that?
  #52
Old 07-12-2019, 08:57 PM
KubotaOrange76
It seemed pretty easy to me once i got the correct tap
yall tell me what im missing
elbow is a banks someone put on with the banks exhaust before me
  #53
Old 07-13-2019, 01:42 AM
aawlberninf350's Avatar
aawlberninf350
aawlberninf350 is online now
It's a Van Gogh
aawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud ofaawlberninf350 has much to be proud of
Since you wrapped the down pipe I'd suggest wrapping the up pipes. Conserve energy to the turbo.
For tapping the manifold for the EGT gauge make sure you can get to it when reassembled. I'd recommend doing that after it's all back together. It's easy then too, and you know it will be easy to get to later if needed. Plus it helps to have things like EGT probes in common places to facilitate apples to apples comparisons. Consider dual EGT probes, one on both sides. Aids diagnosing a problem left to right side.
  #54
Old 07-13-2019, 08:29 AM
KubotaOrange76
I plan to tap the driver manifold for egy down low
i didnt wrap the down pipe it was already like that. I wish i had the motivation to wrap the up pipes etc but this is my wife's daily driver. Its just stating stock unless i can talk her into trading my 17’ with me
  #55
Old 07-13-2019, 01:39 PM
KubotaOrange76
Bout to fire her up
  #56
Old 07-13-2019, 04:50 PM
aawlberninf350
It's a Van Gogh
Swift progress!
Good call on the split heater hose to protect the worn 42 pin harness. And the power steering line.
The clamp on the up pipe collector to the turbo: can you get a wrench on that now that the cab is back on? Mine is oriented so a socket on a long extension fits from the driver side. Might not matter, with bellowed pipes you won't need to get in there anytime soon.
  #57
Old 07-13-2019, 07:31 PM
KubotaOrange76
Honestly i dont know on that clamp
the last 4 hrs ive been diagnosing a no start with a diesel tech friend of mine. Buzz tested injectors and checked everything. Appears the ipr is bad. I must have some how messed it up putting the orings in it? Going to order new motorcraft ipr and try it out
no air leaks no fuel leaks no oil leaks . It will run on gas rag with glow plugs unhooked. Checked all connections grounds et c
anyone have ideas based off codes? I tried with icp , ipr unplugged which i think is the codes above. Also i did not know i had the capability to an injector buzz test before and my #1 injector is weak but that wouldnt give a no start
  #58
Old 07-13-2019, 08:05 PM
Walleye Hunter
Get a reading on your injector control pressure.
  #59
Old 07-13-2019, 08:11 PM
KubotaOrange76
How do i do that? Forgive my ignorance?
can i do it with forscan?
  #60
Old 07-13-2019, 08:13 PM
timmyboy76's Avatar
timmyboy76
Sorry bud but, cab has to come back off..
Monitor icp while cranking
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
