2001 f250 7.3 up pipes and pms
Here's one example and it looks like you are on the right track.
you need to tap and plug the cut off plunger port which is best done with it reomoved
or get a new deleted pedestal
stickies have a mod link for this too
https://www.ford-trucks.com/forums/1...nfo-links.html
Here's a good place to get hpop hoses.
What the heck is Mercon 3? Was it Dexron 3?
Be gentle putting the fuel line back on the fuel pressure regulator, it's just pot metal and they break easy. Billet replacements are available.
Good luck with the broken thermostat bolt. At least it's in front. Could always drill it out since it's a thru bolt.
Gonna have to do water pump
bolt had a hard spot in it i was able to drill about 1/8” that was it
broke out the torch and got overzealous and blew some aluminum off
oh well!!
so water pump and two hpop hoses
might as well go ahead and rebuild the motor while im at it
the old dextron/mercon3
oh well!!
#28
So i Hit up riff raff for some new hpop hoses,
navistar water pump as well as fittings on heads. Ouch that hurt .
forgot to mention yesterday i deleted the fuel heater as well. Back at it again soon
i have to mention in replacing all these fuel bowl and hpop orings all of them were still soft and not nicked . Kind of surprising. The only ones so far that were brittle were oil cooler and ipr. For whatever thats worth
#29
Put new alt idler and tensioner setup on
pulled pedestal apart to discover i didnt have a 1/4” pt tap like i thought. And apparently none of the stores open on sunday around me do either.... so another set back.
went ahead and knocked out vc gaskets harnesses and glowplugs and yanked the old water pump off that i managed to butcher with a torch ����
