Overload springs out...airbags in??
Hi, seems I have just enough pin weight to make the overloads slap when going over frost heaves or bridge decks etc. Its a bit annoying.
Has anyone taken the overloads out and put bags in? I can't see a problem but want to canvas the masses before i go do something stupid..
I know I can just put the bags in without removing overloads but may still get the slap so would like to get rid of them.
Thoughts?
Cheers
Thoughts?
Cheers
allYou have me stumped on how to reply to this...your comment has nothing to do with the questions.
I guess if you want to drive 20km/hr on our Alberta major highways by all means help yourself but warn me so I'm no where around.
Cheers
Cheers
Thoughts?
Cheers
Thoughts?
Cheers
Why not install a set of Torklift upper Stable Loads to pre-load the upper auxiliary springs so they don't slap? I would go this route versus removing them and adding air bags. Air bags are great if you dont have the oem upper auxiliary springs, but since you do, I would maximize them. My experience has been that bags eventually wear out as rubber cracks and air leaks develop.
If you remove a spring you will change the overall weight capacity of your truck and air bags won't make up for the loss. You didn't mention what, if anything, you haul or tow but I'm guessing with a dually you do one or the other. I've had both Timbrens and Air Bags in my F250 and they only helped level the truck when under load.
Trailer rides level now with about 2 inches of squat but with these installed it should still squat enough to keep it close..
Do you notice much empty ride quality difference with them?
Thanks for the input..
Cheers
I've been thinking about going that route. I just don't want our non-towing ride to be any rougher than it is. The thing is, my goal is to eliminate squat, and ride level, but any kind of timbren or torklift seems like they need to have the truck squat before they even come into play.
Timbrens you can adjust the space before contact but too little will give you a rough unloaded ride. Had them on our last truck and they worked great for my application.
Seems to me that the Torklift upper Stabilizers will be in contact when unloaded so start helping right away.
I'm the opposite..I am best with at least a couple inches of squat but can't stand the slapping noise cause i don't have quite enough weight on overloads to keep them engaged..
Cheers
You are correct about losing air and no overloads..That would require immediate attention. Food for thought.
Cheers
here is our set up..rides almost dead level with about 2 inches of squat.
Cheers
Cheers
A Jayco Eagle HT 28.5 rsts. 10995 max weight. It squats a little now, mostly empty, resting on one end of the helper springs and almost touching the other end. I figure when full of stuff, the squat will be something I will want to deal with. Just thinking about it at this point. Agree that I don't want to put the trailer too nose high either, but I think my trailer axles are rated high enough that a little difference won't put them over weight. I'm just looking and thinking now, our first 2 week trip is coming up, so I'll get a better idea how it sits loaded and I'll get some measurements on level ground.
