New F250 owner
Welcome to the club pal. The search feature is your friend. As for oil, that's like asking what the best baseball, football or hockey team is. Personal choice. There are oil threads here.
Run Motorcraft filters; oil and fuel. Air as well and you won't have warranty issues. Fuel additives are personal choice as well. Try to buy from a reputable station.
I let the truck tell me when to change, usually 7200 to 7500 miles. Changed my fuel filters at 22k, 33k miles and will change them after this oil run is up. I have 44k now. That will be an every other oil change, change fuel filters then routine for me.
Check out dieselfiltersonline.com
I dropped my trans fluid at 30k, dropped pan and filter, added two small high temp rare earth magnets to factory pan and used Mercon LV. Added appropiate amount if LubeGard Platinum to trans as well. I did transfer case as well...this was at 31k or so. Plan to do it again at 60k. Maybe keep filter then do again at 60k with filter change. We'll see. Haven't figured that out yet.
I run MC 10w30. YMMV. Read manual. Good luck.
Like Overkill states . Use motorcraft oil, fuel and air filters. They are high quality and will help avoid any possible warranty hassle. As far as oil goes. Many good choices. Motorcraft 10w-30 is excellent. I have run motorcraft10w-30, cj4 (not ck4) delo 400 5w40, and valvoline premium blue 5w40. My 6.7l likes the delo400 the best. I get no typewriter noise (a common phenomenon with some oils for the first thousand miles or so after an oil change)with it, and the oil analysis On it looks great. I change my oil about every 5000 miles or so. That works out to twice a year for me. Change my fuel filters every other oil change. But I drain the water separator every oil change, and after I go on trips with questionable fuel stations. Also I run motorcraft pm22 fuel additive for fuel pump lubrication and cetane boost.
Check online and see if you can find a PDF of the 17 manual before you buy one. I would think you will be able to find one.
https://owner.ford.com/
Last edited by kper05; 07-03-2019 at 07:11 PM. Reason: lynnmor got it covered... i got distracted and had the page opened for a bit!
djousma
6.7L Power Stroke Diesel
10-04-2016 04:18 PM
lilrams09
6.4L Power Stroke Diesel
15
04-15-2014 04:53 PM
Lt CHEG
10-02-2011 06:48 PM
