Car question for you peeps. My Freestyle starts no problem cold. Once warmed up or driven to operating temp and shut off it will not start until it cools down. Not much when I google it. Possibly a reflash of PCM but I don't see how that would solve it. Another said possibly the starter. Wondering if anyone has heard of these symptoms before?
Is it cranking over fine and just not starting or doesn't it crank? Can you hear the fuel pump running? Don't really know whats going on. Haha. Just throwing some quetions out.
Ok, so a little more info might be good. Everything comes on as it should. It's like there is no power to starter at all. Gonna have to check it when I get home and its warmed up good. Maybe starter, relay?
Yeah that helps a little. Haha. Yeah could be starter relay or the starter solenoid on the starter since it would get plenty hot down there after the motor is warmed up. Have to see where you have voltage going too. Could always have Mason try and start it and you tap on the starter with something.
