The Official July 2019 New Jersey Chat & BS Thread
#76
Received 3,090 Likes
on
i found out today my 2020 Kenworth T880 is no good for the Turnpike. i was the slowest truck on the road, doing the federally mandated speed limiter setting of 65 MPH.
i staid in the right lane with my emergency warning lights on, but still almost got rammed over 10 times.
#77
Well, Tom strikes again
That stupid Freestar is still here haunting me. axle in, then the wheel bearings had to be replaced because the abs sensors are IN the wheel bearings.
While pulling the axle on the passenger side, I used a crow bar to push the lower control arm down and the whole motor popped up in the air
Sooooo. Ordered a new rear motor mount, and started taking the old one out.
The bolt on the top welded itself solid, so have to take the whole bracket off.
The cat is right there on the bottom, so the last bolt won't come out.
I had a pry bar trying to convince the cat to give some clearance, and Tom came up and sat on the pry bar.
CRACK
The bottom of the aluminum oil pan busted out
The 5w20 I put in there yesterday ain't in there no mo...….
CRACK
#78
AFTER you clean up the 5w20 you spilled...…..
#79
on
hey now, i told you i was too big to sit on that bar, but you insisted i was the proper weight needed for clearance.
#85
#86
I bet the look on his face was priceless when he realized that. He was thinking "I finally got by that ahole in the dump truck and I will pull in front of him..hahaha...oh sheit!!!!!... there is a damn trooper and I am screwed. Do I keep going and pass the trooper or try to squeeze in between him and the dump truck that I just passed????"
#90
Good Wednesday morning New Jersey, Steve, Craig, Neil, Tom, Charlie, Shaun and Crew. Remember 2 days until the weekend.
