94 IDI 7.3 Turbo transmission swap exhaust problem
Old 06-30-2019, 01:10 PM
Tom Brown's Avatar
Tom Brown
Tom Brown is offline
I have a 94 7.3 turbo. It needs a new clutch.
The passenger side top bell housing bolt is nearly impossible to get at, as a bracket for the turbo exhaust downpipe is blocking the bolt. Worse still, the bracket is held on by the bolt it's blocking.
I may be able to bend the bracket to make room to remove the bolt.
From there, I'm guessing I'll have to cut the exhaust to get it out of the way, as the trans has to come straight back.
There is a v-clamp holding the downpipe to the turbo output. Can someone tell me if there is a sleeve in there? The v-flanges don't budge when I wiggle the exhaust pipe with a bar. I hope I don't have to cut that pipe near the turbo.
I'm sure plenty of folks here have swapped DMF to SMF on a Turbo 7.3 and have needed to pull the ZF-5 to do so. Any info would be appreciated.
Old 07-09-2019, 04:59 PM
Tom Brown's Avatar
Tom Brown
I will provide an update in case someone finds this thread using a search in the future.
- The top starter bolt on a manual transmission is nasty but doable. Count on 30 minutes for just that one bolt, if you were laying on your back like I was.
- The v-clamp on the turbo exhaust is much easier to get at if you pull the air box and I think removing the airbox is required for the top, passenger side, trans bolt.
- Pressure plate bolts don't come with an SMF clutch kit and are NLA from Ford. Be gentle with your old ones. Torque to 21 ft*lbs.
Old 07-12-2019, 03:33 PM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
Received 3,078 Likes on 2,148 Posts
when i did the trans swap on my 88 i found it was much easier to remove the floor pan and access all the bell housing bolts through the giant hole it left.
Old 07-15-2019, 05:25 PM
big ole ford's Avatar
big ole ford
big ole ford is offline
I concur wholeheartedly with this statement. With that removeable cover out of the way it makes pulling the trans ALMOST easy!
Old 07-16-2019, 12:47 AM
Tom Brown's Avatar
Tom Brown
I did it without pulling the trans access hole and it wasn't horrible but I can see it would be easier with that hatch removed.
Thank you for the advice, gentlemen. Hopefully, it will help someone who might find this thread via a search.
PstrokeN
08-21-2011 05:15 PM
Vinford
12-23-2008 05:26 PM
esperkins
12-27-2006 11:12 AM
86F250_MOTORIDER
09-25-2006 02:28 PM
89ford73
11-05-2004 07:02 PM
Quick Reply: 94 IDI 7.3 Turbo transmission swap exhaust problem
