Is it Possible to Put Power Steering On My Truck
Old 06-28-2019, 09:34 PM
Ford1959F100's Avatar
Ford1959F100
Ford1959F100 is offline
Ford1959F100 is starting off with a positive reputation.
Hello , I have a 1959 Ford F100 4WD Truck , and i want to put power steering on it. I've done hours of research and have called many businesses asking what product may fit. they all do not know because it's 4WD.i want to know if it may be possible or anyone else has put power steering on their 4WD truck.
Old 06-29-2019, 03:39 AM
oldbleu's Avatar
oldbleu
oldbleu is offline
oldbleu is gaining momentum as a positive member of FTE.oldbleu is gaining momentum as a positive member of FTE.
Did you try Classic Performance Products (CPP)? They might be worth a call. They have a power steering kit that fits a 2WD Fridge. I am guessing, but the only issue would probably be the drag link fitment.
Old 06-29-2019, 04:50 PM
Ford1959F100
Yep sadly
I had called them and asked about what would work, they said they are not sure and have never put it on a 59 4WD and that they really donít know. I donít think there are many Factory 4WD 59ís made, it seems to be rare. Luckily for me all fords records from that year burned in a fire, so I guess Iíll never know.
Old 06-29-2019, 06:13 PM
Byrd.Dog's Avatar
Byrd.Dog
Byrd.Dog is offline
Byrd.Dog is starting off with a positive reputation.
I have the CPP box on my 60 F250 4x4 with 35" tires & so far it's working fine.
Old 06-30-2019, 01:39 AM
Ford1959F100
Talking Thanks for the info!!
if you don't mind me asking, what transmission do you have?
Old 06-30-2019, 09:05 AM
Byrd.Dog's Avatar
Byrd.Dog
Byrd.Dog is offline
I'm running a 400 with a C6. Hadn't thought about clearance issues with the slave cylinder...
Old 07-12-2019, 01:49 PM
Ford1959F100
Question i have a question
what kind of alterations did you have to do to fit the 400 with the C6 Tranny?? and what type of transfer case are you using?
Old 07-14-2019, 09:36 PM
Byrd.Dog's Avatar
Byrd.Dog
Byrd.Dog is offline
Had to do custom motor mounts, cut out the factory rear engine/trans crossmember, and fab a new transmission crossmember. My C6 has the "short" tailhousing, so I was able to use my factory divorced T-case by having a new shorter intermediate driveshaft made.
Old 07-15-2019, 07:23 PM
robski_1970
robski_1970 is offline
robski_1970 is starting off with a positive reputation.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
