1978 - 1996 Big Bronco
Budget 5.0
Old Jun 27, 2019 | 01:21 PM
Kolt Carter's Avatar
Kolt Carter
Budget 5.0
Hoping to make around 300whp in my 1992 Bronco. It has the roller cam efi 5.0. Looking for suggestions on cam and head choices. Low to mid range powerband.
Old Jun 28, 2019 | 01:05 PM
AbandonedBronco's Avatar
AbandonedBronco
A lot of this depends on what your budget is, and if you're doing the work yourself.
What budget are you looking at?
Old Jun 28, 2019 | 03:28 PM
Conanski's Avatar
Conanski
What year is the motor?
Go find a set of used aluminum heads from a mustang guy that is upgrading... like the Eddy Performers, put a complete exhaust system on it with headers, put the Comp 35-349-8 cam in it and the motor should make over 300hp at 5500rpm give or take. The powerband will be 2500-5500rpm which is as low as it gets with this motor, axles should be geared to utilize that rpm range while taking into account tire size, so 3.73-4.10s are the bare minimum. This level of upgrades requires MAF and a tuner to make the larger than stock injectors and MAF meter cooperate with the PCM, an aftermarket EFI system, or a carb conversion so I hope the budget has room for that too.
Old Jun 28, 2019 | 08:04 PM
Kolt Carter
How much minus the exhaust (I already have hooker long tubes with true dual magnaflows) do you think the upgrades will cost. It is a 1992 so hydraulic roller cam.
Old Jun 28, 2019 | 08:06 PM
Kolt Carter
I'm doing all the work myself so I need stuff that doesn't require machining and max budget is 1,700
Black Ford XLT
Jan 27, 2016 12:44 PM
cjrupp
Apr 12, 2013 07:05 PM
dustybumpers
Aug 21, 2011 09:39 AM
TheTowingCowboy
Feb 25, 2010 10:17 PM
pipman76
13
Jan 4, 2010 08:53 PM
