Should I even bother with a diesel this time?
I'm getting ready to trade in my 06 Cummins and was looking at the 2017+ Power Stroke. After a few weeks of research I'm starting to wonder if it's even worth buying a diesel anymore. All the emissions crap they have slapped on the newer diesels seem to be more prone to causing problems and really expensive ones at that. Low sulfur at the pumps, DEF fluid, EGR issues, head gasket problems, injector problems, fuel pumps ruining engines because of American diesel standards plus the $10K addon just for the diesel engine in the first place. Diesel used to be way cheaper than gas when I bought my first truck back in 2001, that didn't last long. Now it's typically more expensive than premium. I don't tow often but have always wanted to have enough truck to do it if I needed to and have needed to several times. I really like the torque of a diesel engine but it seems like the reward is just not that big anymore unless you're towing things a lot where you really need that torque. What do you guys think? Have any of you went from a diesel to a full size 3/4 or 1 ton gas truck and regretted it? Kind of on the fence now and I never have been before. Thanks for any input.
I had a gasser p/u, not a Ford. Hauled a little because I could only haul a little. I got a medium sized TT and it struggled. I got my first diesel, ‘15 F250, because “I don't tow often but have always wanted to have enough truck to do it if I needed to and have needed to several times.” Hmmm, who said that.?? Oh yeah, you did.
Upgraded to a 5th wheel because I wanted to and because with that truck I COULD.
Get a gasser and you’re limiting yourself but if you are sure you’re not going above the limit then happy hauling/camping.
The 6.2 is beefy for sure but the 6.7 is BEEFIER
I had head gasket issues on my 05 Duramax, the 6.0 PS was notorious for it. The 6.4 PS had fuel pumps eating themselves. I had 2 7.3 PS that ate transmissions and now have a Cummins with injector issues. The PS upgrade for ford is over $9K and the Cummins is just about $9k. I used $10k to round it off. I haven't made up my mind exactly and Alleydog had a good point, I wouldn't have the best truck to pull a fifth wheel if I wanted to by going to a gas engine.
The 6.7 is a $9120 option, I just went from a F150 6.2 to and F250 6.7 and I'm happy i did. Like others, i dont tow too often, but when i do, it's usually for long trips through the mountains. Sooo, I'm my case, I made the switch and so far so good. The 6.7 is wonderful.
Head gaskets are a non issue on the 6.7s as are injector problems. Yes, the CP4.2 HPFPs are finicky, but the fuel pump issues are blown out of proportion. Keep clean fuel in it and properly prime the system during fuel filter changes and you won’t have issues. The emissions systems have come a long way since 2008. They do add complexity to the truck, but with each passing year model, they are getting better. If you want the diesel, but the emissions scare you, you could do the 6 letter word that starts with “D”.
Drice a 6.2 every day at work (2014). Capable engine. Tow periodically with it (7-8k). Gutless in my opinion. Gotta let it scream to feel like it’s getting anything done. Extended cab 2wd shortbed. Averages 15 MPGs empty. 7-8 towing. They have been extremely reliable. So have the 6.7s. We have started buying diesels again in the 4 and 550 trucks. 6.4s soured the company on Ford diesels for awhile so the 6.8 V-10 has been the workhorse for our fleets. Averaging 4-6 MPG while the 6.7s in the same application are sitting 10-11.
Everyone raves about the 2017+ 6.2s with 4.30 rears. They are peppy. Go drive both and see which one you like. Don’t let reliability fears keep the 6.7 out of the equation. They have been great.
My first diesel was a 2012 Cummins, which I deleted immediately. This was at the recommendation of the dealer, as most of their problems were emissions related. Emissions have come a long way in just a few short years. People hated to see DEF systems added, but if you're gonna leave the engine stock you're much better off with it. I'm really impressed with the 6.7 Powerstroke so far. Stock, it feels really, really close to the 2012 6.7 Cummins with a 100 hp tune!
Well sir, I went from a 6.2 gas to a 6.7 diesel. The 6.2 did OK pulling my big 5er, just very busy and could not push it without dumping a LOT of gas in it. Generally kept it around 60 or a little less and got around 7 MPG towing. A lot of hills were in 2nd or 3rd gear @5000-5500 RPM. Never overheated or anything. Traded it for a new ‘15 King Ranch 350 dually. Towing was a dream, but that truck was an electronic nightmare from the second day I had it. Lemon laws in that state only covered up to 10,000 GVW. Went back to the dealer where I bought it, and he cut me a hell of a deal on a new ‘16 King Ranch 350 dually with a 6.7, and that truck was flawless. Pulled like a beast. As long as I have a big 5er (18000GVW) I won’t go back to gas. The only reason I now have a Ram is I have a couple of friends with them, and they really like them, and the Ram dealer here cut me a great deal (10K less than a KR for a Laramie Longhorn) so I thought I would give one a try. And regardless of what the Ram fanboys say, my ‘16 6.7 with 3.73 gears would out-pull this Cummins 6.7 HO with 4.10 gears. But it is still also a good truck so far. With all this being said, if you want the oil burner, go for it.
It's not where I live in Colorado. Some places are the same and the most I've seen it cost more is $.15 a gallon
