Seafoam in a BRAND NEW Engine?
Ya. Same thing just one picture is closer and at a different angle
Interestingly enough, as I was doing some research on engine break-in procedures, I found this article in the July-Sept 2017 edition of Engine Professional Magazine.
http://www.engineprofessional.com/ar...Q317_62-66.pdf
It mentions a two-year study about break-in of roller cams, although it gives no actual link the study itself. Also seems to be written by an oil company rep so read into that what you want. Interesting though. I'd like to find the study and read through its' findings.
TBH, if I ever build another engine in my life that came with flat-tappet lifters, it's getting rollers
New Problem
So I received the replacement lifter set. What do you know...No more ticking noise! I have driven now about 40 miles and believe I have a misfire on cylinder 4. I pulled the wire and had no change in exhaust tone or engine smoothness. I also have a very loud popping noise from the exhaust above 1500 rpms under load. I scoped Cylinder 4 with an in-cylinder pressure transducer and compared it to the waveform of a good cylinder(cyl 3) and they look identical. So, mechanically, cylinder 4 is sound. I have good spark also. I changed out the vacuum hose to the brake booster because it was cracked and it draws vacuum from the cylinder 4 runner but still misfires. I’m getting a ticking/squeaking noise intermittently from the cylinder as well. Just wondering if anyone has any ideas.
Engine Specs:
410 cubic inch FE
Factory 428 crank
Factory con rods
Silvolite pistons
Lunati roller cam, lifters, timing set
Trend custom pushrods
Proform adjustable roller rockers
Edelbrock performer heads with stainless valves
Edelbrock performer intake
MSD pro billet dizzy
MSD 8.5 wires
NGK spark plugs
Hedman headers
True dual exhaust with manga flow mufflers
Holley sniper efi
I have the sniper controlling timing advance. Initial timing is 6 degrees. Max advance is 35 degrees. Seems to misfire at all rpms. The popping from exhaust is basically there anytime you are past 1/10 throttle.
Engine Specs:
410 cubic inch FE
Factory 428 crank
Factory con rods
Silvolite pistons
MSD 8.5 wires
NGK spark plugs
Hedman headers
Holley sniper efi
I thought about it. I probably will today. I'm wondering if my timing needs advanced a little. If I remember correctly, I had the same ignition and fuel setup on my 360 and initial timing was set at about 15 degrees.
Here are the waveforms I collected to verify the condition of the cylinder mechanically:
This is cylinder 4. Looks pretty good. Has all four strokes and good compression for an engine with 40 miles on it
This waveform is Cylinder 3. A known good cylinder. I collected this waveform as a reference for comparison.
As you can see they are mostly identical. I will change out the spark plug this afternoon and see if the problem improves.
Update!
I now have about 80 miles on the truck and the noise has subsided. The engine seems to be running a lot smoother as well at least to 3000 rpms (I haven't gone over that threshold yet). I guess I'll just file that one under the engine break-in section. I did change the spark plug on Cyl 4 and adjusted the timing to 15 degrees so that could have played a part as well.
One additional question: I plan on using Royal Purple HPS oil in it after the break-in but am unsure of what weight to use. The break-in oil I'm using is 10W-30 and I have about 20 psi at warm idle. Should I move up to 10W-40 or just stay with 10W-30?
#28
I set timing by total mechanical advance about 36 degrees and just let initial end up where ever it does which is usually around 12.
Glad things are smoothing out for you.
#29
10w-30 should be more than enough for your engine...….if you can find 5w-30 or 0w-30 that would be even better but you will be ok (since it will flow on startup much faster)....BTW, congrats on the engine!!!!!!!!!!!!!!!!!!!!!
VitaminC
64
09-22-2021 11:34 AM
bigblockford_390
19
09-01-2021 12:06 PM
80ford100
38
03-25-2018 10:44 AM
73F100*8Mile
16
12-23-2007 04:38 PM
