Modular V10 (6.8l)
2009 6.8l V10 issues? What to look and watch out for?
Old 06-16-2019, 10:09 PM
stevenmwardjr
stevenmwardjr is offline
stevenmwardjr is starting off with a positive reputation.
So I'm in the process of searching for a truck, my top candidate is a 2009 F250 XL, its optioned how I want and is a good clean slate, it's got 97k on it but the seller appears to have a lot of fleet trucks, so it might be a lot of idling hours on the motor.
How would I find out how many hours are on the motor, also what do I need to check and watch out for with this motor?
Old 06-17-2019, 05:12 AM
JWA's Avatar
JWA
JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
I've read an advanced near-dealer level scanner can read the PCM's accumulated hours of operation. Not sure if FORScan can do this but a good shop with advanced level scanner would be a good place to start I'm thinking.
Old 06-17-2019, 09:50 AM
DesertSmoker
DesertSmoker is offline
DesertSmoker is starting off with a positive reputation.
You can get the info off the console display. Ford says the motors are good for 4000 hours.
Old 06-21-2019, 12:42 PM
Sancho
Sancho is offline
Sancho is starting off with a positive reputation.
My 2009 f350 has about 130k, 3100 hrs. So far, no oil consumption. Engine oil analysis shows no abnormal wear.
Old 07-01-2019, 04:58 AM
Mcrafty1's Avatar
Mcrafty1
Mcrafty1 is offline
Mcrafty1 is gaining momentum as a positive member of FTE.Mcrafty1 is gaining momentum as a positive member of FTE.
You say 2009 XL has the accumulated hours on the console display? I have one but have yet to see the hour meter, how do I get that to come up? My 07 lariat 6.0l comes up when I cycle through the dash display but the 09 hasn't popped up when I do that?
Sorry for the Hijack but this may help the OP also.
Old 07-15-2019, 09:07 AM
DesertSmoker
Mcrafty,
I have to do an oil change this up coming weekend so I will try to figure out how to get back to the hour meter display.
Old 07-15-2019, 09:16 AM
johnfist
johnfist is online now
johnfist is starting off with a positive reputation.
On my 2008 I just push the dash button on the cluster and it comes up at some point. Should be the same for the 09. Not sure if the truck needs to be running or not.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
