Power rear slider
Power rear slider
How embarrassing to even ask this.... I will admit that my reading comprehension ain't the best.
I've read the manual in the glovebox and can't find this:
Power rear sliding window fuse. Is there one? It won't open, it is broken shut which is better than the alternative I suppose.
2007 Powerstroke Lariat. Extended cab.
Tia!
Tia!
I have done exactly that, bought a complete rear slider including the rubber from evil bay, I could have probably fitted it myself but chose to let a local "old school" windscreen fitter do the job. I bought a generic window switch & ran the wires to the motor, The motor mounts to the rear panel, but does prevent the fold flat seat from latching back as intended. (This is not a problem for us as our dog travels with the seat flat & I rarely carry back seat passengers) I do intend to rework the back of the seat around the motor to allow it to locate as it should.
Retrofit Rear Power Window
Retreever
I'll take a couple of pics later, the cost was around $400 for the rear window & seal, the switch & wiring I already had, the labour for fitting the window was some beer, I did the rest myself. My truck is a 2000, built late '99.
Thanks
Thanks for the info
Was the 2011 Power Slider that you found in a junk yard gasket set or urethane set?
In 2008, Ford changed the installation method of OEM back windows to a urethane set method, eliminating the gasket.
1999-2007 models were previously all gasket set (two different types of gaskets, depending on if manual slider or Power Slider).
However, if a Ford Accessories Power Slider was added after the fact of production to a 2008 or newer Super Duty, it may very well have the same gasket set mount as the earlier Super Duties, and just require more work cleaning the urethane from flange.
But if the Power Slider was assembled into the truck at the factory, then I believe those backlites were urethane set for the 2011 model year, which makes me curious what you found in the junk yard on a 2011. Gasket set or urethane set?
How did you set the 2011 backlite in the 2005 cab?
trainmuzik
03-14-2013 09:33 PM
mds062778
2004 - 2008 F150
15
10-23-2004 12:13 AM
