2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
BROKEN into last night, you are not gonna like this
Old 06-12-2019, 06:10 PM
17 Oaks's Avatar
17 Oaks
17 Oaks is offline
The truck broke into last night around 12:30 they might have heard me coming as they only got some money (car wash quarters) and that was it...It was late and dark I did not notice, everything looked normal in the dim light. Drove home, wife used truck today and noticed the door handle surround looked like it was out of place slightly, she looked again then looked thru the truck and my car wash quarters were gone:
Details:
I had a doctors appt last night to look at some sleep patterns. I was in an office but less than 75 ft total from the truck.
I INSURED the truck was locked and the alarms were on as I was in San Antonio.
There were only 2 cars in the parking lot, my truck and the docs car.
I went in about 8:30 and out at 12:30.
I never went to sleep so it called at 12:30 and I left. This tells me the ALARMS NEVER WENT OFF.
Wife stop by Ford and its about a $300 fix, ok, fine will do it.
Page 2
Ford man who works on the Superdutys and does a LOT of these showed my wife how with a small flat blade screwdriver they can get in the truck in less than 15 sec, he told her Superduty's have the worst locking system of any truck made. He told her the word must be out because the SD's are starting to pour in the dealership. Worse it is barely noticeable. It is so easy and fast that it's being done in the daylight hours in busying parking lots, it looks like you are just putting the key in and unlocking the truck. Its nothing but a stab and grab...I had lots of stuff in the truck and thing they grabbed was some quarters.
And WORSE, there is no cure, nothing you can really do to prevent
Old 06-12-2019, 06:29 PM
wicked 2018's Avatar
wicked 2018
wicked 2018 is offline
weird no alarm. Sucks - sorry that happened and yes these trucks are way to easy to get into.
Old 06-12-2019, 06:34 PM
zeroo's Avatar
zeroo
zeroo is offline
How do you do it with a small flat head? Pop the handle off?
Old 06-12-2019, 06:39 PM
17 Oaks's Avatar
17 Oaks
17 Oaks is offline
The Ford guy showed my wife how its done, I was not there. She said you pull out the handle, insert a flat blade right behind it and hit with the palm of your hand and open the door, that easy...
CBEllis's Avatar
CBEllis
CBEllis is offline
Guns & Money - don’t leave either in the truck. I could empty my truck into a paper grocery sack. Got broken into in SA also but they grabbed the lock cylinder and twisted it. No alarm, no horn, no flashing lights...
I do hate a thief.
Old 06-12-2019, 06:51 PM
wicked 2018
I do hate a thief.
When people break in like this, does turning the lock cylinder trick the car into disabling the alarm? Its crappy enough its so easy to do, even worse if the "computer" thinks its a normal entry and turns the alarm off
Guess if you have keyless entry you can just buy a passenger handle and remove the lock cylinder completely to avoid it.
Old 06-12-2019, 06:53 PM
zeroo's Avatar
zeroo
zeroo is offline
Ok, just watched a video. Holy crap that’s easy. The truck thinks the key was used is why the alarm doesn’t go off. I have a push button, wish they had left the keyed entry off.
Old 06-12-2019, 07:04 PM
wb6anp's Avatar
wb6anp
wb6anp is offline
Install jimmy jammers and remove the lock cylinder. I just did that on mine.
Old 06-12-2019, 07:08 PM
VA13FX4's Avatar
VA13FX4
VA13FX4 is offline
There’s 2 ways of breaking into these trucks. One is manipulating the lock cylinder and the other is manipulating the lock rods.
I read a post a while back about someone attempting to put the rear door handles on the front doors and remove the lock cylinder all together. I can’t find the thread now to see if it was accomplished.
However, the option I have seen talked about the most is “Jimmy Jammers”
They have two separate solutions for these trucks. A plate that goes on inside the door panel to block access to the rods, and a plug to put in place of the lock cylinder.
Both are necessary to make the truck less easy to get in to. Of course a thief will get in if they really want. And there’s even a possibility of there being more damage if a thief knows how to break in and then can’t. But if you leave more in your truck than just loose change, you might want to look at this option:
https://jimmijammer.com/JJ%20description,%20113700.html
I’m in no way affiliated with the product. I just researched them when I was living in the SF Bay Area. Now that I live in Maine I’m not so worried.
Old 06-12-2019, 07:10 PM
BillyE's Avatar
BillyE
BillyE is offline
Wouldn’t this also apply to F-150s since they share the same cab? There must be some reasonable fix. Sucks.
Old 06-12-2019, 07:11 PM
VA13FX4's Avatar
VA13FX4
VA13FX4 is offline
Yup! The 2015 and up 150 people have the same issue.
Old 06-12-2019, 07:16 PM
zeroo's Avatar
zeroo
zeroo is offline
With the jimmy jammers and removing the lock, breaking in any other way should set the alarm off.
Old 06-12-2019, 07:17 PM
zeroo's Avatar
zeroo
zeroo is offline
Is the door a pain to take apart?
Old 06-12-2019, 07:50 PM
Alaskan_Warbird's Avatar
Alaskan_Warbird
Alaskan_Warbird is offline
I understand that the door panel removal/reinstall can be a PITA. I intend to do mine at some point in the future because the dog chewed the top of each front door panel ($700 fix if I do it myself!). I'm going to replace the front door speakers and do something to make it harder to break into, at the same time.
Old 06-12-2019, 07:51 PM
jimzpsd's Avatar
jimzpsd
jimzpsd is offline
I learned years ago to never lock my doors. No matter what measures you take to "prevent" a break in............they will still get what they want. By leaving the truck unlocked I no longer worry about a forced entry by a smashed window or a broken handle/lock cylinder. You want it, take it, I leave nothing of value in it when I leave. Alarms might scare them away but by then the damage is already done.
The following users liked this post:
Quick Reply: BROKEN into last night, you are not gonna like this
