2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
How soon can you use synthetic oil?
Old 06-12-2019, 07:25 AM
Mattm400
Mattm400 is offline
Mattm400 is starting off with a positive reputation.
Got 950 miles on my F250 6.7. Was planning on doing first change at 2000. Can I switch to full synthetic at that time or does it need more break in with dino oil first? I know some vehicles have synthetic from factory, just wondering if there's a reason why these dont.
Old 06-12-2019, 07:50 AM
Wes Hightower's Avatar
Wes Hightower
Wes Hightower is offline
Wes Hightower is starting off with a positive reputation.
I did mine at 950, 6.2L.
Old 06-12-2019, 07:55 AM
HRTKD's Avatar
HRTKD
HRTKD is offline
HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.HRTKD has a spectacular reputation.
The factory oil is 10w-30 dino. Switch when you want. I did my first oil change at 5K and went with full synthetic, Valvoline PBE 5w-40.
Old 06-12-2019, 07:57 AM
Mattm400
Mattm400 is offline
I know the 6.2 has synthetic blend from factory. My F150 did anyway.. just wondering why the 6.7 is conventional oil.
Old 06-12-2019, 07:58 AM
FOURBYBUD
FOURBYBUD is offline
FOURBYBUD is starting off with a positive reputation.
I always do mine at first oil change. Usually around 500 miles.
Old 06-12-2019, 08:13 AM
HRTKD's Avatar
HRTKD
HRTKD is offline
$$$? Break in? Beats me. I had heard that older diesel engines took a long time to break in and running synthetic oil extended the break in period. I have no idea what the break in period is for the 6.7L.
Old 06-12-2019, 08:21 AM
AlphaInfinity
AlphaInfinity is offline
AlphaInfinity is starting off with a positive reputation.
I started running Rotella T6 in my superduty starting at 5000 miles. I live in an area with extreme temperatures so we always switch out the oil on our diesels to full synthetic. I will do it a lot sooner if “winter is coming” hehe.
Old 06-12-2019, 09:17 AM
Chinookman's Avatar
Chinookman
Chinookman is offline
Chinookman is gaining momentum as a positive member of FTE.Chinookman is gaining momentum as a positive member of FTE.
With current milling processes, have read on many forums that 'break ins' were pretty much not a requirement.
Of course when its our money we tend to be more cautious, right.
As I have read in the past, Corvettes and Mustangs come with full synthetics from the factory.
I did my 6.2 at about 7k cause I'm cheap and got the free oil change of the blend at about 5k. At least it did allow draining of all the machine fines.
Running Pennzoil Platinum, and for what its worth have been watch the trip meter average climb from a 12.6 to 13.4 mpg and that was about 1400 miles ago.
If in doubt, cause it is your money, do the first oil change in the blend to drain the fines and about 5k later go with full synthetics.
As far as brands go that will always open up a can of night crawlers....lol........and good for another bazillion posts.....
Old 06-12-2019, 09:58 AM
ForCal's Avatar
ForCal
ForCal is offline
ForCal is gaining momentum as a positive member of FTE.
I have 2 free oil changes so I guess I'm stuck with whatever the standard change is. Those who did the first change early, like 500mi., was that at the dealership?
Old 06-12-2019, 10:11 AM
minke
minke is offline
minke is starting off with a positive reputation.
The only time that synthetic is worse is when you get your wallet out.
Old 06-12-2019, 01:09 PM
Mattm400
Mattm400 is offline
Ok, thanks for the replies. With all the oiling and injector problems on my 6.0 I was just making sure I'm headed in the right direction on this one!
Old 06-12-2019, 01:34 PM
HRTKD's Avatar
HRTKD
HRTKD is offline
Welcome to the 6.7L world. There aren't many problems with the 6.7L. The most common injector problem seems to be when someone puts gasoline in the diesel tank and drives off.
Old 06-12-2019, 07:00 PM
RONMCHUGH's Avatar
RONMCHUGH
RONMCHUGH is offline
RONMCHUGH is starting off with a positive reputation.
I'm about to go to full synthetic at @ 15k . Also Valvoline PBE .
Old 06-12-2019, 07:09 PM
Chinookman's Avatar
Chinookman
I have been following this guy for some time and he does a great job in his home made lab testing set up.
This link is the middle of a series of oil performance play offs. You can tell he really gets into it and enjoys what he does.
He just did the grand finale' and will not spoil the ending.
But it seems this topic never gets old and this happens to be an unbiased play off series of many brands.
All test material is out of pocket so he gets no sponsors. Some of yah'll probably saw this set of tests and just forgot about it....
Anyway when you see which brand came out on top I'm betting this thread will blow up lol.....enjoy fellas .....aaaaaaaaannnnnd ladies....
Last edited by Chinookman; 06-12-2019 at 07:11 PM. Reason: lil 14" lpatop spells badly....yeah that's it...
Old 06-12-2019, 08:20 PM
dirthawg's Avatar
dirthawg
dirthawg is offline
dirthawg has a good reputation on FTE.dirthawg has a good reputation on FTE.dirthawg has a good reputation on FTE.
I'm going to say somewhere between 10,000 and 15,000 miles. Somewhere in between those numbers is when the Iron in my oil began to level out.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
