Delete question
Old Jun 12, 2019 | 06:11 AM
rjrandy96's Avatar
rjrandy96
Delete question
So I’m getting ready to install my off-road pipe today for use on the fam only of course. And I don’t know what to do with the sensors in the dpf? Do I just zip tie them up? Disconnect and then and just tie up the wires? I am saving my dpf Incase we ever re purpose the truck if that changes anything. Also should I drain my def tank?
Old Jun 12, 2019 | 07:05 AM
dirthawg's Avatar
dirthawg
Best thing to do is use dummy plugs from shibby engineering $99 for the basic kit. https://www.ford-trucks.com/forums/1...l#post18462157
Others pack the connectors with dielectric grease and use the fingertips from rubber gloves with a zip tie to cover the ends.
Old Jun 12, 2019 | 07:10 AM
cjssr's Avatar
cjssr
I second using the Shibby Plug Kit. It will save you from having codes, blown fuses and issues others have experienced leaving the plugs get moisture into them.
Justus6.0L
Mar 20, 2018 10:48 AM
trshman
Dec 4, 2011 12:58 PM
rokhedjo
Modular V10 (6.8l)
Apr 6, 2011 02:40 PM
f15097
1997 - 2003 F150
Jan 30, 2011 05:42 PM
crawlfish
Dec 4, 2004 04:54 PM
