Jacking
Whatever you do, do not put the jack under the rocker panel; it will collapse. There are these cross-structures inside the rocker panels that are meant for jacking. If you still have the original jack, there might be a picture of the areas where you're supposed to place the jack. However, that may not jack up the entire side of the van as you want for tire rotation. Maybe if you deployed two jacks, one in front and one in back.
there are front and rear jacking points on each side and I use two jacks to rotate tires.
the factory jack is used to raise the rear and a hydraulic jack to raise the front, but both under their jacking points.
the jacking points are located behind the rocker panel sheet metal. They are flat and reinforced to handle the weight.
