What do you know about 351W?
Old 06-09-2019, 05:07 PM
RedBox88's Avatar
RedBox88
RedBox88 is offline
RedBox88 is starting off with a positive reputation.
Hi everyone !
I wanna know what do you know about 351 windsor? How to tell the difference between a 351W and a 351C? Some people thought I had a 351 Cleveland in my truck
Well, explain me that !
Old 06-09-2019, 05:57 PM
Conanski's Avatar
Conanski
Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
Hey... Redbox88. What truck do you have?
The 351w was part of the only Ford "small block" family to ever get EFI starting in 1987 and the Cleveland was a short lived performance engine from the '60's that was never factory installed in a truck, so while it is possible to put one in a truck it would have been a DIY effort somewhere in the vehicles past. The 351/400m family did see use in these trucks in the '70s - '80s and that is the motor that most people mistake for a Cleveland.
Old 06-09-2019, 06:14 PM
baddad457
baddad457 is offline
baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.baddad457 has a great reputation on FTE.
Originally Posted by RedBox88 View Post
Hi everyone !
Cleveland has 8 valve cover bolts, Windsor has 6. Cleveland's intake is "dry", the coolant comes out of the block above the timing cover, Windsor's coolant exits from the intake. Cleveland also used the small block bellhousing pattern and motor mounts, the 351M used the big block bell pattern (429/460) and it's own unique motor mounts. Cleveland's timing cover is integral to the block, with a flat steel plate covering it. And finally, the Cleveland's fuel pump bolt pattern is vertical, Windsor is horizontal.
Old 06-09-2019, 06:27 PM
RedBox88's Avatar
RedBox88
RedBox88 is offline
Ive a 1988 F-250 Custom 5 speed with a 351W ! And thanks !
Old 06-09-2019, 06:28 PM
RedBox88's Avatar
RedBox88
RedBox88 is offline
Thank you!
Old 06-09-2019, 06:33 PM
baddad457
Thank you!
Anytime !
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
