90 460 coolant bypass hose
Old 06-08-2019, 11:15 PM
1974 f100
1974 f100 is offline
1974 f100 is starting off with a positive reputation.
just picked up this f250. needs coolant hoses badly. there is a bypass hose next to the lower coolant inlet hose. same diameter. very sharp 90 to a very close inlet. is there a way to install a new hose without removing the water pump? tried warming new hose in the sun and using soap on the inside to make it slip on easier. no luck. other ideas/shortcuts? perhaps soaking hose in hot water? Many thanks for your input. Thanks...Roger
Old 06-10-2019, 07:27 AM
jas88's Avatar
jas88
jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
Silicone spray on the inside of the hose.
Old 06-10-2019, 03:41 PM
1974 f100
so far i've tried first soap then vasoline. both helped but still no go.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
