Massive oil leak
Did I hear you say on video you have a hole in timing cover? Mine was trying to eat the cover before timing job . I have seen pics of lots of them with holes from the chains and wedged guide parts many in the very top by the phasers .I believe you can carefully weld them so as not to warp them from heat or epoxy them ,I don't know what a new one costs.
https://www.partsgeek.com/catalog/20...ing_cover.html dorman $149.
Well you know that means you need a full timing job. Your guides are broken and your tensioners not working . Plastic in oil pan and fibers jammed in oil pu reducing oil flow . New chain ratcheting steel tensioners melling ,guides ,new oil pump melling hv . Drop oil pan and see--clean out and pull oil pu -fibers are tuff to get out .They will not come out oil drain. You will have shiny alum grindings in sludge in bottom of oil pan . After cleaning oil pan and timing job do the new oil conventional cheap and change out after a few miles or days maybe with an engine flush then use good oil . There will be crap in oil after timing job , I did a flush before and after timing job .This engines oil flow system not good it needs melling hv oil pump and cleaned real good .Wally world mc filters are cheap .
Chain system better not be dry ever. Old style ratcheting tensioner still available and no gasket to leak . Factory oil pump not good and dash oil gauge reads mid scale for anything over 7 psi --its an idiot light- shame on ford for making it look like a gauge.Look at ford tech malukoco you tube on this engine ,you will learn a lot . Never use aftermarket phasers .
Jourdan_D
04-03-2013 09:24 AM
TMF
04-24-2009 07:31 AM
dapozer
01-03-2006 07:42 PM
