Sponsored by: Real Truck
2013 sync freezes
Old Jun 2, 2019 | 04:08 PM
elishaman's Avatar
elishaman
2013 sync freezes
My 2013 f350 with 30k miles has a problem with sync/ entertainment. It will freeze about every 3rd time I drive it. I have to remove the fuse and reinstall to get it to work. Had it to dealer several times and no problem found, but they did tell me I needed a new back up camera?????? Back up camera works fine, sync not so much. I know ford did an extended warranty for apim issues. I am now past the warranty period. Any ideas besides running it in the river and buying a truck that systems actually work on. I know this is my last ford vehicle.
Old Jun 2, 2019 | 04:29 PM
Just Strokin's Avatar
Just Strokin
What version is your SD card Maps? The latest is A10. You can get them off eBay for less than $45.00.
What version of Sync 2 is loaded? The latest Sync 2 version is v3.10 (not to be confused with the later Sync3 in the 2017 and newer SD trucks).
You can create a profile at the Ford Owner site and with a thumb drive (USB drive), download the update or maybe go here and downloaded it...
my OneDrive
https://1drv.ms/u/s!AmfH21s7Qw_LgVOT0fVxiDLdx_Qo
or
https://forum.xda-developers.com/win...c-2-0-t3484473
Old Jun 2, 2019 | 05:28 PM
elishaman's Avatar
elishaman
Ok I will check that out. The dealer told me that the latest updates were on it but my dealer is crap.
Old Jun 2, 2019 | 06:33 PM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
After you download the latest update from a thumb drive or even before delete all your previous destinations and any favorites that you aren't using, then disconnect the battery instead of the fuse for 5 minutes. This system seams to run out of memory easily, but its from Microsoft so what do you expect.
Denny
Old Jun 2, 2019 | 07:06 PM
Just Strokin
There is a master reset that will clear the memory of all saved items. Not sure disconnecting the batteries will.
Old Jun 2, 2019 | 07:13 PM
elishaman's Avatar
elishaman
I have done master reset but will not fix problem
Old Jun 2, 2019 | 07:17 PM
rvpuller's Avatar
rvpuller
Master reset won't clear any memory but it will give it a hard boot just like you do on a Microsoft computer. It's worked for me in the past.
Denny
Old Jun 3, 2019 | 04:45 AM
Just Strokin
By chance, has the Sync module located on the passenger A pillar been replaced? If not, I might consider replacing it or at least reseat the connectors.
Old Jun 3, 2019 | 06:37 AM
elishaman's Avatar
elishaman
No the sync module has not been replaced
Where exactly is it located and I will try thst
Old Jun 3, 2019 | 07:38 AM
Just Strokin
This might be the APIM that contains the Sync?
If you drop the glove box door, you will see the TPMS module and then behind it is the Sync module. It is mounted on the A pillar.
Old Sep 13, 2020 | 04:19 AM
Deuce40s's Avatar
Deuce40s
Do you have an update to this issue?
For the past few weeks, my Sync needed to perform scheduled maintenance every day and reset. I tried pulling the fuse a few times, then tried the master reset. None of which fixed it. I then uploaded the latest version of Sync and all was well for a week. Now I'm back to the same issue and last night Sync never loaded at all. It tried resetting 4 or 5 times on its own but kept crashing.
k7lvo
6.7L Power Stroke Diesel
Jan 25, 2017 08:01 PM
ciscofreak
Aug 12, 2015 08:32 AM
sandyc
Sep 6, 2010 07:51 PM
GwizRC
Jan 16, 2009 11:31 AM
Drive-By
2004 - 2008 F150
Aug 23, 2004 09:12 AM
