Grandpa's Truck F250 Supercab Camper Special Ranger XLT
#91
#93
#94
So there's no chance of reaching in there with on of those grabbers that you push the button and possibly fish it out? From your photo, it looks like there's a good enough gap to reach in there with a grabber. Perhaps drain the oil and look in there with a really bright flashlight to see if you can see and retrieve it.
#95
#96
Managed to get that brass ring out of the oil pan, with the assistance from a metal coat hanger.
Anyways, onto my question. Does this look right? Normally I'd consult my book. But, I left it in the trunk of my BMW. I'm having it serviced while were on out on our Oregon coast trip
I should add, the old timing gear and chain I took off of this thing, it was looser than hooker on nickle night. It very may well have skipped a tooth.
#98
#99
It's amazing how much difference can be made by changing out worn timing gear. On your old sprokets... did they have that plastic/nylon coating on the teeth? If so, how much of it was broken off? I renewed timing gear on a 289, a 318, and a Slant 6. They all had that nylon (I guess it's nylon) coating on the teeth... I guess it's supposed to make it quieter. But seriously now... who here has changed timing gear and later said, "Wow... that's kinda noisy without the nylon!" I know I never noticed a difference in noise on my cars.
Much of the coating on the teeth was broken away on the old sprockets... which really created a lot of slack. Was probably the reason why my Duster and Galaxie both jumped time. On the Slant 6, it wasn't near as bad... but we changed that timing gear before anything bad happened. We were changing the water pump on that car, and decided to go for the timing gear since we were so close having the water pump off.
#100
#103
No, I never did.... it looks as if the aluminum was corroded through. I'm playing it safe and just getting a new one.
