Sponsored by: Real Truck
New here...need advice please
Old May 29, 2019 | 04:29 PM
zacknsam's Avatar
zacknsam
I have a 2010 F350 Superduty 4x4 that I love. The problem is that it has a shimmy in the front end when I hit about 63 mph. Once I get to about 73 it smooths out. What could cause this? Thank you in advance.
Old May 29, 2019 | 04:38 PM
Just Strokin's Avatar
Just Strokin
Could be tires or could be worn steering parts. I would suggest taking the truck to a truck alignment shop and have them evaluate it.
Old May 29, 2019 | 07:01 PM
zacknsam's Avatar
zacknsam
Thank you Larry. The tires are good.
Old Jun 3, 2019 | 05:38 AM
F250edski's Avatar
F250edski
Could be tires need balancing even if they look good.
Old Jun 3, 2019 | 05:59 AM
zacknsam's Avatar
zacknsam
I’ve got an appointment to have that checked. Thanks!
Old Jun 3, 2019 | 06:02 AM
Deuce40s's Avatar
Deuce40s
Are you having them check the rest of the steering components too? Post back up any issues they find, it may help others.
Old Jun 3, 2019 | 09:33 AM
Batman7777's Avatar
Batman7777
I have found by experience, Super Duty truck suspensions require precision balancing since they are more rigid. As you know, small bumps in the road are felt where cars with soft suspension would go unnoticed.
Any off balance will amplify. A balance problem was resolved using a somewhat newer method called, Road Force Balance.
The machine checks for run-out which could be the result of a bent rim or manufacture quality issue. It will also detect and look for out-of-round tires.
Road Force balance attempts to match imperfections of the tire to the wheel and its imperfections.
You need to have closer to perfect tires, alignment and balance on a heavy duty truck. Not less
One more thing, you need to have someone who knows what they are doing with the balancer. Two places I went just didn't really know what they were doing.
At the third place (Les Schwab), the mechanic was very experienced. The truck never road so smooth. No more bounce at any speed.
Old Jun 3, 2019 | 09:56 AM
RenoHuskerDu's Avatar
RenoHuskerDu
Couldn't he have a case of looming DW?
Old Jun 3, 2019 | 04:48 PM
geekwithoutacause's Avatar
geekwithoutacause
A GOOD alignment shop will check it out for you and tell you what it needs. It could be a number of things wrong/worn out. Ball joints is one.Steering box... etc etc
aqnhfd
Feb 20, 2018 06:40 PM
midsouth
Mar 20, 2012 06:50 PM
fordtruckman
2004 - 2008 F150
Nov 22, 2010 07:54 PM
scstocks94f150
Jul 3, 2008 05:50 AM
FireTail-AR
Apr 23, 2007 07:33 AM
