header for my 88 inline six
Old Oct 3, 2003 | 10:54 PM
mixme123's Avatar
mixme123
can anyone tell me where to find a single out header for my 88 300-6.
Old Oct 4, 2003 | 09:39 AM
Silver Streak's Avatar
Silver Streak
I've never seen or heard of one. Clifford used to list one in their catalog, but when I called about it they said it never made it to production. Even if it had I wouldn't have bought it from them. They were jerks when I called that time and every other time I've talked to them. After three tries I decided they weren't worth doing business with.
Old Oct 4, 2003 | 11:12 AM
mixme123's Avatar
mixme123
where can i find a 3-2-1 header
Old Oct 4, 2003 | 02:42 PM
jwtaylor's Avatar
jwtaylor
I was under the impression that the earlier pre efi headers where single outlet, then again I cannot be sure. Call www.jegs.com and ask them about their dynomax or hooker headers they have listed for the 83 and down 300. Yours is efi and I know when I got mine they were dual but again I believe the pre efi where single. you may need to modify an earlier set to fit your needs. Call them and find out, you can go to the jegs website and look but the picture is of a v-8 header, that does no good, so your gonna have to ask, later
Old Oct 4, 2003 | 10:19 PM
optikal illushun's Avatar
optikal illushun
hedmen used to make a single outlet header, i seen on on ebay a while ago. i was gunna bid on it until i saw it was single outlet...maybe on of thier older models??
Old Oct 5, 2003 | 01:14 AM
wildjon300ci's Avatar
wildjon300ci
Cliffy fed you a line of BS.....That's what I run on my truck. But I'll NEVER EVER do buisness with Clifford again after the hassel and long wait it took to get my header. And when I got the header I had to have 3 holes welded. Not what you expect for $350.
Old Oct 6, 2003 | 01:05 AM
strait6man's Avatar
strait6man
im looking for a headder too but mine is a 85 non fi
Old Oct 21, 2003 | 10:58 PM
william_ace's Avatar
william_ace
i have one on mine, its not good for city performance but on the hwy it made a good bit of difference. and i have 33's with the stock gears so if i had regular tires i bet i would be able to tell a larger difference. clifford is where i bought it.
Old Oct 24, 2003 | 01:47 PM
Frdbuy8589's Avatar
Frdbuy8589
I thought that efi motors had banks of three then a y pipe. I also thought that these maniflods flowed just about the same as a header. Maybe this was 92-96 150's? But I think you can use the stock manifold and run straight pipes or true dual exhaust and elimate the y pipe stock cats and 2inch pipe for high flow cats nice dual mufflers and pipe.
Old Oct 24, 2003 | 06:58 PM
chuckman's Avatar
chuckman
its true that the EFI manifolds (dual, three bank) flow pretty good, but there still not headers, and long tubes traditionaly produce more torque than shorties in the first place.
