I’ll try it but I don’t think it will considering I drained the bowl completely and tried turning the key with the lid on and it didn’t fill a drop. Had to fill it manually. I’m gonna pull the line off the front of the pump and see if it’s even pumping
I missed that part somehow. Then you need to figure out why fuel isn't flowing. If you could attach a hose to the rear of the pump into a container of diesel and try that. While you're back there you can try sucking out of the fuel tank and see if you have a problem from the rear.
Think I found the problem. Parts will be in tomorrow. Also found the top half of a gas can stuck in the filler hose. Once I replace these I will let you guys know what’s going on.
Well I did the hutch and harpoon. Ended up putting a new fuel pump in. Fired right up after that. Ran for about two minutes then once I gave it gas I noticed it seemed like a miss then it died out and won’t fire at all. When it first started it was blowing a lot of white smoke. Now it don’t blow anything when cranking over. Back to square one. I’m almost to the scrapping point
I’m getting a lot of pressure up to the bowl. I ran the pump and then cracked that valve in back and fuel sprays everywhere. Had a bunch of air in it at first but it got better after doing it awhile
Still no hits. Just sits and cranks. Should I replace the Ipr? I remember someone saying something about the relays behind the dash by the radio. Should I test those?
Check the fuel filter. Who knows what might have been trapped in the lines and with the new pressure blew through.
