Diesel Tank Size
Diesel Tank Size
How can you positively know what size fuel tank you have? Nothing I have found states what size I have. The manual lists "Fuel Tank (176 inch wheelbase, middle location) as 48 gallons but then right below it, it says, "Fuel Tank (incomplete vehicle, middle location) as 26.5. I hate to us the word assume, but I thinking mine is 48 gallons? I just traded in my 6.7 2011 F250 4x4 for a full sized F350 dually and it has the 176 inch wheelbase. Absolutely nothing on any of my paper work states what size tank it is.
Alternative, you could have used the scientific method and driven it until you had an eighth of a tank left then fill it up. Does it take 40 gallons, or only 20? Be aware these trucks tend to have a large amount of unusable fuel reserve (not really a reserve, but to keep the fuel pump covered). My truck has the 34 gallon tank, but I have only once had it take more than 29 gallons in nearly two years of ownership.
I too want to do this upgrade, at least to the 2016 I have. It’s just difficult to swallow the $1600 cost for the extended range. However it would be awesome to go 600-700+ miles on a tank of fuel.
Titan 50 gallon aftermarket tank questions
Hey guys; Ford Newbie here
I am considering the Titan 50 gallon aftermarket tank on my 2016 CC with the 26 gal. factory tank.
Will the fuel gauge work properly?
Will this screw up the computers in any way? I would expect the mileage to empty would be messed up but can the dealer program the computer to show the fuel capacity is 50 gal?
Thanks
Thanks
Thanks
Thanks
2012 F250 4x4 CCSB ..... I installed the Titan 50 gallon tank a few years back. It is a great addition. The Ford engineers must never have driven in the 4 Corners region where I live. 26 gallons is a pathetic design. Round numbers ..... only 23 gallons usable, (never want to run it dry), 10 mpg towing, 230 mile range, 50 miles between gas stations, range reduced to 180 miles, and the then there is wind and grades. In southwestern New Mexico is saw a highway sign .... No Fuel Food or Lodging Next 125 Miles. My $0.02.
Yes the 26 gallon tank is rather pathetic, actually very surprising that Ford went with this size of tank after GM did for however many years and people hated it. Granted they fixed it when the LMM engine came out and had a 30+gallon tank, kind of like the 2017 Super Duty's have it figured out. Wish a long box tank would fit underneath, but they won't. Will upgrade to the Titan tank once I'm pissed off enough about the lack of range with the 26 gallon tank while towing. On my recent move to Arkansas from Wyoming I didn't dare push it much farther than 150 miles before getting fuel. Was rather inconvenient in some towns to pull a 30 ft bumper pull into their stations, and I've noticed diesel must not be as prevalent in a lot of areas, lot of pumps were old and dated and didn't accept cards, had to go pay inside first. 1st world problems.
I put the Titan 50 gallon tank in my truck. The gas gauge does work. You have to use Forscan or have the dealer modify the miles to empty calculation. One thing to remember is that an 8th of 50 gallon tank is much more than an 8th of a 26 gallon tank so when the low fuel light comes on depending on your miles per gallon you get close to 100 miles till empty. I can say that in my opinion the Titan 50 gallon tank is probably one of the best additions that I've made to my truck.
