06 F-150 fuse box confusion.
Received 3,101 Likes
on
my neighbor just picked up a 06 F-150 2 wheel drive with 4.2 V6 for use as a beater.
got a pretty good deal, $3,000 with a low mile engine. original engine blew when it overheated after radiator blew.
truck has a little over 80K miles, engine is a little over 35K. i was going through it and cigar lighter was out. plugged in to OBD port, and that was out too. went to change fuse, but it was good. found a blown 20 amp in spot 41, which is tagged " not used" in diagram. changed it and lighter and OBD port came on.
is there a misprint in the fuse box diagram for the 04-08 F150 that FTE has in archives?
The owner's manual for that truck does specify that F41 is the lighter and the OBDII port. Suggest your neighbor download a copy if the original is missing.
on
on
