Replaced hydro-boost now have soft brakes
i gravity bled to get the fluid started after replacing the rubber lines then proceded with a mightyvac. i'll give the LH side on a slope method a try. BTW, this is on my 08 6.4L, there just isn't as many people posting/replying on that forum so I asked over here, should have stated that first. I wasn't aware that you cannot remove the master out of the way on the 7.3 like you can on the 6.4. Sorry for some of the confusion.
*edit* I depressed the brake pedal with a 2x4 pressed against the seat to prevent continuous fluid flow while I was replacing the lines, removed the 2x4 gravity bled then used the mightyvac.
No, I plan on replacing the fronts and the one on top of the axle. I just replaced the rears because I knew the RR was bad by how it bled (or more like didn't bleed).
on a side note, I noticed my join date. July 18 2004. 15years ago. Man the knowledge I've gained from this site! love it.
