Forscan help please
Look for MAP sensor reading.
Boost is just the MAP minus the barometric pressure.
What you want to monitor depends on what issues you suspect you might have.
These are common ones:
ICP pressure
ICP volts
ICP desired
IPR% duty cycle
FICM MPower
FICM LPower
FICM VPower
VGT % duty cycle
MAP or boost
EOT - Oil Temp
ECT - Coolant Temp
TFT - transmission temp
Baro
EBP
If you are troubleshooting a no-start you want to see cam/crank sync, FICM sync, and rpms.
ICP pressure
ICP volts
ICP desired
IPR% duty cycle
FICM MPower
FICM LPower
FICM VPower
VGT % duty cycle
MAP or boost
EOT - Oil Temp
ECT - Coolant Temp
Baro
EBP
indyraven
07-09-2014 01:47 PM
