Decals Instead of Painting for Hubcaps, Hood Spears, etc?
I have a 51 F1 with the single hood spears. I just got them back from Showtime Restorations, who did a fantastic job straightening and polishing the stainless steel. Before I sent them to him, I had attempted to straighten and polish them myself. I got them to a point where they were fair, so I painted the "FORD" and the "F-1" with black automotive paint. Of course, it didn't stick, so I stripped it off, spent hours masking, then sandblasted and repainted. That worked well, until I decided that the spears looked like crap and sent them to Showtime to polish. I stripped the paint before I sent them. Of course, the polishing process also polished up the painted sections, so I now have to mask, sandblast, and paint.
I have seen some custom decal work, most notably the work of Firstrider for hubcaps and the Magic Air Heaters. (Got my Magic Air Heater from Denny and it is a work of art!!)
So, is there anyone that has had this done and is willing to share. I did ask Denny on his Magic Air post thread, but thought it would be better as a separate general question.
Any thoughts?
John
Any thoughts?
John
You might try taking your hubcaps and hood trim to a local sign shop. They have the equipment and resources to make most anything from scratch like that. There is a pretty high set up cost for this kind of thing., so you'll have to determine if it's cost effective for you to do a one-off. Get several quotes, because the costs can vary greatly depending on how willing a shop is to do it.
One method I’ve used for many years dating back to 74 when I painted between the ribs of the valve covers on my 64 Corvette is to use vasoline on areas you don’t want paint to stick, then paint the area in question,. After the paints dry wipe off the vasoline. I use an old t shirt wrapped around my finger to wipe it off. Look at my Suzuki’s wheels that I just painted the cast parts gold. No masking at all. Works very well.
Jersey Devil - Where'd you get your trim rings? Looks sharp!
As far as getting a pattern, any decent shop should be able to do a 'rubbing' of the part and then scan in to use with their software. If they don't, you could try rubbing the impression out on some paper with some charcoal strips or pencil. Then they could scan in and produce die-cut vinyl decals.
Just a thought.
Just a thought.
imlowr2
19
10-25-2005 08:27 PM
