Pan gasket/rear main or both?
Truck is a 1984 F250 4X4 w/460. Picked it up Monday, and on the drive home I stopped at a gas station to top it off. Notice a steady oil drip underneath it, checked oil and it was down half a quart although it was full 100 miles earlier. Once home, I pulled the inspection cover and here is what I could see. Notice the travel route of oil between the rear of the pan and bell housing plate. Either way I know it is a job to fix and will more than likely do both of them, but I just want someone else's opinion.
Best guess would be rear main and when you do that it is good to know you must set the crush on the seal when installing it. I did not know this the first couple times I did one but it is quite important I think it is 010 to 015 and while the pan is off get one of the rubber reusable pan gaskets they make now, little spendy but not too bad and they save a whole lot of headaches in my opinion.. They are a one piece gasket so very little sealant is needed if any..
grizzly11
16
11-08-2010 07:43 PM
trinogt
05-22-2003 12:02 PM
