1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
1993 E350 Motorhome Rattling and Power Loss
Old 05-20-2019, 04:36 PM
mikeinri
mikeinri is offline
mikeinri is starting off with a positive reputation.
Hi guys,
Vehicle is a 1993 E350 motorhome, 7.5L gas with automatic transmission, approximately 80k miles.
The problem is an intermittent (but fairly reproducible) hollow rattling/chattering sound, accompanied by a loss of power to the wheels. The noise appears to be coming from the engine area (forward of the driver's seat).
This happens primarily in third gear, and sometimes in OD, especially after coasting and then lightly accelerating (feathering the pedal). It happens anywhere from 30-60 mph.
If I press harder on the gas, the noise grows, and there is still reduced power. When I pull my foot off the accelerator and push it harder, it operates normally (even without downshifting).
I took this to a truck shop, who said the noise was coming from a rotted exhaust heat shield. They didn't think they'd be able to find a replacement, so they put a clamp on it to tighten that down. The noise is less since they did that, but that was obviously a side effect symptom of all this vibration.
I plan to bring it to a Ford truck dealer. I'd love to hear ideas before I go and get taken for something silly.
Thanks in advance.
Mike
Old 05-23-2019, 10:49 AM
mikeinri
mikeinri is offline
Any ideas? Could this be as simple as a tune-up / timing issue?
Mike
Old 06-14-2019, 02:27 PM
77trailerspecial's Avatar
77trailerspecial
77trailerspecial is offline
77trailerspecial is starting off with a positive reputation.
did you ever figure out this problem
Old 06-14-2019, 02:36 PM
jimbomitch
jimbomitch is offline
jimbomitch is starting off with a positive reputation.
Clogged exhaust will give you a loss of power.
Old 06-14-2019, 08:57 PM
77trailerspecial
Do you mean the cat because I have been dealing with same issue
Old 06-15-2019, 06:50 AM
mikeinri
mikeinri is offline
No, not yet. It does throw an occasional (rare) CEL, so I need to read the codes.
Problem is, the CEL light is always on dimly (when engine is running), so I need to fix that first. I'm hoping that's as simple as cleaning the green crud off the back of the instrument cluster (I noticed that while fixing something else last year).
So, my plan is to clean the cluster, read the codes, deal with any issues there, and get a good tune-up.
Mike
Old 06-15-2019, 03:56 PM
jimbomitch
Yes, Cat or any exhaust obstruction. Sometimes big rust flakes internally can block parts of the system. Or rodents can set up house in the system.
Old 06-16-2019, 03:11 PM
Rick Andriashek
Rick Andriashek is offline
Rick Andriashek is starting off with a positive reputation.
I have the same problem with my 1992 E350 motorhome. I am looking for a solution as well dealer here had no idea.
Old 06-17-2019, 09:55 AM
mikeinri
mikeinri is offline
BTW, this loss of power is only at a specific (low) throttle range. If I let off the gas and then punch it, it has plenty of power.
Mike
Old 06-18-2019, 02:18 PM
Maillemaker
Maillemaker is offline
Maillemaker is starting off with a positive reputation.
The catalytic converter on my 1990 E350 RV recently started knocking. It's because the honeycomb inside has broken. It hammers at idle but at speed the exhaust presses it in place so it can't rattle.
Old 06-20-2019, 03:23 PM
mikeinri
mikeinri is offline
Does it throw a code (CEL) when that happens?
Mike
Old 06-25-2019, 12:01 PM
Maillemaker
Mine is not throwing a code. At least, the CEL is not on.
Steve
Old 06-27-2019, 08:49 PM
ABSBoltSuicide
ABSBoltSuicide is offline
ABSBoltSuicide is starting off with a positive reputation.
Anyone figure this out yet?
btw, what are the dates of the posts?
thx
Old 06-27-2019, 09:39 PM
Maillemaker
The dates of the posts are at the top of the post.
Old 06-29-2019, 06:36 AM
subford's Avatar
subford
subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Sounds like a bad Throttle position sensor (TPS) on the OP 1993 E350.
The sound would be a lean fuel mix.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
