1992. 460 F250 Manifold/carb switch
Old 05-20-2019, 01:02 PM
Rotorpilot
Rotorpilot is offline
Rotorpilot is starting off with a positive reputation.
I was given a an Elderbrock intake manifold and Holly 4 barrel carb for a 460. My question is how hard and what would be needed to switch out the fuel injection to a carb and what installation problems may occur.?. Any help with this would be appreciated.
Old 05-20-2019, 03:04 PM
mrollings53's Avatar
mrollings53
mrollings53 is offline
mrollings53 is gaining momentum as a positive member of FTE.
Stick? Easy.
Automatic? C6? Easy. E4OD? Pain in the dick.
SEARCH IS A THING
Old 05-21-2019, 07:17 AM
Rotorpilot
Manifold /carb switch
Thanks for the response. Standard trans. Im going to go for it.
Old 05-21-2019, 08:51 AM
Rotorpilot
Manifold carb switch
Ok , one last question I hope. The Edelbrock manifold I want to use is an older type manifold. My engine is a 1992. My question is when I remove the fuel injection will ANY 460 intake work.Thanks for the help.
Old 05-21-2019, 08:58 AM
timbersteel's Avatar
timbersteel
timbersteel is offline
timbersteel has a good reputation on FTE.timbersteel has a good reputation on FTE.timbersteel has a good reputation on FTE.
I'm curious about your question.
I know that 460's had different heads for EFI.
Someone else can chime in. I know Diesel Brad is well versed on the 460's and several other members.
You may want to do a search.
Good luck!
Old 05-21-2019, 09:00 AM
rla2005's Avatar
rla2005
rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Only EFI intakes will work. You are better off getting an adapter for a carb to fit on top of the existing EFI manifold since the intake ports (and exhaust) are in different locations for EFI versus carb. heads.
http://www.pricemotorsport.com/html/body_ca-460efi.html
Old 05-21-2019, 09:03 AM
timbersteel
^^^^ Exactly what RLA2005 said!
I forgot to include you RLA2005. Thanks for clearing up his question.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
