Worn Pinion Yoke
I appreciate all the responses.
I've finished with the seal replacement. Now that I've had it apart and back together, I see now that -- just as you stated -- that wide groove I was concerned about was not from a bearing. I ended up reusing the yoke ( a new one is $100+).. The pinion nut was very difficult to remove and reinstall -- I'm not sure if it is supposed to be that hard, but I couldn't get the nut back on with a 90 psi impact wrench; I had to use a 3x torque multiplier to get it retightened. As we got near the old nut position, it clearly become nearly impossible to move the nut, which is where we left it. At this point, if the seal doesn't hold, I'll just take it to a transmission shop in town. Thanks again.
That nut should turn somewhat hard, so it stays where you put it and doesn't turn loose, but not necessarily that hard. As long as you got it tightened the correct amount is all that matters. It should be tightened JUST enough to take all up and down sideways play out of the yoke.
midwestbird
08-06-2020 09:40 PM
rosesrfree4u
04-15-2012 07:55 AM
jmonintwo
12-30-2007 02:23 PM
AK F150
12-28-2002 01:43 PM
