2015+ F150 Discuss the 2015 Ford F150
Went to test drive yesterday
Old 05-19-2019, 06:50 AM
adock
adock is offline
adock is starting off with a positive reputation.
So I finally got out to test drive some trucks yesterday. I narrowed it down to an STX crew cab shot bed with either the 2.7 EB or the 5.0. I was really impressed by the EB. It had good power and it just felt lighter and more nimble. The only two concerns I have are the turbos adding more points of failure and the exhaust note just isnít a V8 lol.
I currently have a 2011 Forester thatís been a bit of s problem child. Itís had 4 valve cover gasket replacements since 60,000 miles, the short block was replaced at 92,000 miles for oil consumption now Iím at 115,000 miles and I have some valve tap with a considerable blow by. This has made me more hesitant to buy anything more complex than a naturally aspirated engine. Previously I had a 2002 Tundra with the 4.7L and the only ďcomplaintĒ I had with that was the gas mileage. I knew it wasnít going to be good when I bought it but at the time I felt I didnít use the capabilities of that truck to justify the low mpg thatís why Iím leaning towards the EB since Iíll only loose a few mpg from the Forester.
I guess my last question is about pricing. They currently are offering the crew cab shorted 4x4 STX with the 2.7 for $38,236 before tax title and all that bs. Is this a good deal or should I try to get more off? I think the msrp was around $46,000
Thanks
Old 05-19-2019, 06:58 AM
GABAR's Avatar
GABAR
GABAR is online now
GABAR has a good reputation on FTE.GABAR has a good reputation on FTE.GABAR has a good reputation on FTE.
Thanks
Before you make your decision, are you sure the STX has everything you want on your F150?
Have you tried looking around at other dealers in and out of your area?
The reason for the second question is that believe it or not, some dealers still have some new 2018 F150Ďs on their lots and you might be able to score a higher trim level for a better price than a 2019 F150 because nothing changed from last year to this year.
Old 05-19-2019, 08:50 AM
ATC_F350's Avatar
ATC_F350
ATC_F350 is online now
ATC_F350 is starting off with a positive reputation.
Holiday Ford is showing $10.4k off on their STX trucks. They are in north Texas.
Old 05-19-2019, 10:04 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is online now
ford390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud offord390gashog has much to be proud of
I would choose a 2.7 over the new 5.0 if I was in the market. Far to many issues with the 5.0.
Old 05-19-2019, 10:10 AM
adock
adock is offline
Unfortunately I donít think I can get exactly what I want from the factory. Iíd like to have the 10 way power heated seats from the xlt but I also want the vinyl floors. I also like the looks of the STX over the xlt. I found a few 18 xlts but they were the extended cab Iíve pretty much ruled that out because I hated that about the tundra.
Old 05-19-2019, 07:28 PM
IndyDog
IndyDog is online now
IndyDog is gaining momentum as a positive member of FTE.
Me too. After 2700 miles it's going into the dealer tomorrow. Oil consumption below the bottom hole on the dipstick, black soot or something on the wall in the garage from when I start it up, and now a popping sound after I let off the gas after mild acceleration. I think I have a clunker and this truck has hardly been driven. Stay away. First vehicle I've ever had to bring to the dealer after so few miles with such issues.
Old 05-20-2019, 05:02 AM
adock
adock is offline
I was reading about some of the problems with the 5.0 and theyíre making me hesitant to choose that. I donít want to get into another lemon.
Old 05-20-2019, 08:55 AM
Kingofwylietx
Kingofwylietx is online now
Kingofwylietx has a good reputation on FTE.Kingofwylietx has a good reputation on FTE.Kingofwylietx has a good reputation on FTE.
...........The only two concerns I have are the turbos adding more points of failure and the exhaust note just isnít a V8 lol.
If you'll do some searching on this forum and the other F150 forums....you'll very quickly realize the turbos are NOT what you should be concerned with on a newer F150. They are probably one of the most reliable parts on the whole truck.
To make them so robust, it seems Ford must have cut corners on their lug nuts, door handles, Sync systems, moon roofs, brakes, transmission, V8 piston rings, 20" wheel coatings ...etc. Turbos are your least likely point of failure....
However, if you just want a the sound of V8...that is a perfectly fine reason to buy the V8.
That's where I bought my truck. The guy that picked me up (no trade-in vehicle, so they sent a driver for me) said that he spends most of his day picking people up at the airport...who flew in to buy from them.
They were super easy to work with and didn't play any games. We did all the negotiating over email. When I arrived, they didn't try to change the deal or tack on add'l fees.
It was probably the easiest vehicle purchase I've ever had. I have to give props to this dealership.
Old 05-20-2019, 09:09 AM
smokewagun
smokewagun is online now
smokewagun has a good reputation on FTE.smokewagun has a good reputation on FTE.smokewagun has a good reputation on FTE.
My recommendation, living with a 2018 truck with a new 2019? replacement 5.0L... stay away from the 5.0L. Until Ford figures out the oil issue, itís just too iffy. Theyíll either get it right, or by the time the 2020ís hit, theyíll go back to cast iron sleeves... or an all new 4.8L. The more I read, the more I wonder what resale will be on a 2018 with the 5.0L once this really gets out.
Old 05-20-2019, 09:11 AM
Bryan-G
Bryan-G is offline
Bryan-G is starting off with a positive reputation.
I love my 2.7 but absolutely HATE the auto shut off that you don’t get with the 5.0 (well at least in 2016). Lease is up soon and if I get another F150 it will have the 2.7 again. Just my opinion. My 2013 had the 5.0 and 2016 2.7. There is no less power, torque or pulling notice from the 5.0 to the 2.7. What you will notice differently is the gas mileage. 18-20 in town, 22-24 highway with the 2.7. I got 13.5 in town and 18 highway with the 5.0. Yes I have a heavy foot and drive hard but you can see the differences in mpg with my driving style.
Old 05-20-2019, 09:23 AM
Roaddriver
Roaddriver is offline
Roaddriver is starting off with a positive reputation.
Test drove the 2019 XLT LARIAT and LIMITED over the weekend. XLT was ok the Lariat was nice but the Limited was unreal. Cant believe where they have taken trucks to these days. Will make a decision this week.
Old 05-20-2019, 09:35 AM
smokewagun
Auto start stop comes with all engine options today. Sorry.
Old 05-20-2019, 09:45 AM
Roaddriver
2019 limited comes with the off button right on dash.
just have to turn it off every time you start it.
Old 05-20-2019, 09:50 AM
Kingofwylietx
All trucks with auto start/stop have the button on the dash to disable it.
It's not trim specific.
There are other ways to disable it permanently.
Old 05-20-2019, 09:51 AM
smokewagun
😆 They ALL do!
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
