Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Catalytic converter cleaners
Old 05-17-2019, 11:11 PM
TBourque53
TBourque53 is offline
TBourque53 is starting off with a positive reputation.
Hi all,
Has anyone had any experience with catalytic converter cleaner. If so can you tell me if it works or not.
Old 05-19-2019, 03:48 PM
PupnDuck
PupnDuck is offline
PupnDuck has a very good reputation on FTE.PupnDuck has a very good reputation on FTE.PupnDuck has a very good reputation on FTE.
Most are worthless snake oil. Why do you believe you need to do this? Did you fail a state emissions test?
Old 05-19-2019, 03:59 PM
TBourque53
Cat cleaners
No, we donít have inspections here in MN.
recently I was driving my 2002 Ford Escape 3.0 when it suddenly lost power.
I was only able to get it up to a lot 20 mph and that was floored. I replaced the rear catalytic converter and it was full of crap.
I took it for a test run and got it up to 55 mph and it suddenly dropped down to 20 mph again. Some one told me that I had to clean the pre-cats and someone else told me to put some of the catalytic converter cleaner instead of going through the pains of trying to take the pre-cats off.
I have a lot of muscle and bone issues but being on disability income I canít really afford s mechanic so I will have to do it myself
Old 05-19-2019, 04:34 PM
projectSHO89
projectSHO89 is offline
projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.projectSHO89 has a spectacular reputation.
The so-called "cleaners" are not going to do anything with a converter that has already crumbled except waste your money.
Old 05-19-2019, 05:00 PM
TBourque53
Ok, thank you for your help. I will try to whack the pre cats around and see if that will help
Old 05-19-2019, 05:35 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
Whatever is causing the converters to load up is the real issue. Even if a product were available that would clean them out, it would not remedy the underlying fault and you'll soon be right back where you started. See if you can pull some codes, that might get you pointed in the right direction. Some engine defect is causing those cats to plug up. That needs fixed, even without the cats installed.
Old 05-19-2019, 05:38 PM
PupnDuck
PupnDuck is offline
You can always try whumping on the Cats with a rubber mallet in hopes that it will break up the ceramic honeycomb inside sufficiently to blow the guts out the tail pipe but in all likelihood you'll just plug up the muffler. Since you live in a state that doesn't have emissions inspections you could have a muffler shop cut the Cats out and replace them with a piece of exhaust tubing. Shouldn't cost too much.
Old 05-20-2019, 08:08 AM
TBourque53
Catalytic converter
Thank you for the info, I found a code that said there was a misfire in cylinder #6. Iím sure with that misfire, it could have caused the cats to plug up. I will handle that first and then tap on the cats and loosen them up
Old 05-20-2019, 02:44 PM
simonsi's Avatar
simonsi
simonsi is offline
simonsi is starting off with a positive reputation.
Hmmm might be more involved than you think given the cats are integral with the manifolds. Once the manifolds are out its certainly easier to just remove the cat guts Iíd think.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
