Main fuel tank
Old 05-16-2019, 02:15 AM
MrGGermany
MrGGermany is offline
MrGGermany is starting off with a positive reputation.
Main fuel tank
Hello all,
2 years ago I bought a 77 F250 Camper Special with 2 fuel tanks. The main (rear) tank is not in use and the PO said it was like that when they bought it, but they have no idea why. Is there a way to check the tank and hoses for leaks or blockages, without pulling it out? I wondered if it either has a leak or it was a safety thing...as in a rear tank can't be used in CA (where it's originally from) in case of a rear-end collision? I also, just this second, realized that I haven't checked the tank selector....maybe it's bad? How can I test the tank selector for functionality?
Old 05-16-2019, 04:33 AM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Used OEM parts guy
77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.77&79F250 has a spectacular reputation.
To check the valve, just turn the ignition key to the right (1st position) and switch the fuel selector switch, you should be able to hear the valve under the truck back on the cross member switch over. If it had not been used in a long time for some unknown reason, I would drop it and insp it. If you put gas in it you might be pumping a bunch of junk into the lines/filter and carb.
That tank drop is not that bad with it empty. My version of tank drop is here. https://www.ford-trucks.com/forums/1...l#post14696841
So says the parts man. "78/79 duel fuel tanks frame switch-Duralast/Universal 3 port fuel selector valve used with SW48 toggle switch Part Number: FSV4"
Old 05-16-2019, 06:07 AM
78Hayride's Avatar
78Hayride
78Hayride is offline
78Hayride is starting off with a positive reputation.
I just went through my system. Replaced both tanks and verified all valves and switches work. It all worked prior but was in need of cleaning. Yes, there was a lot of crud in both tanks. It suprised me. After they dried out I shook them and it sounded like a couple cups of sand were in each.
Old 05-16-2019, 06:45 AM
MrGGermany
Thanks for the help / info 77+79 and Hayride.
Old 05-16-2019, 07:37 AM
Meridian_Mike's Avatar
Meridian_Mike
Meridian_Mike is offline
Built Ford TOUGH
Meridian_Mike is starting off with a positive reputation.
Did you (are you going to) just dump out the dry contents of the tanks and re-fill with gas?
How about these liquid fuel tank "liners" you can put in the tanks?
I am thinking about cleaning my tank and putting the Eastwood stuff inside to refurbish it.
Thoughts?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
