1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
06 Expedition On Sharp Turns will Stall
Old 05-16-2019, 01:18 AM
therealrift
therealrift is offline
therealrift is starting off with a positive reputation.
Bought the Truck back in Nov 18 for 3G's just to be a point A to Point B Vehicle I got my mechanic to fix most problems they could find.
However, this particular problem would happen if I am trying to park into a Tight Space especially if I cut the wheel all the way to the left or Right while reversing and tapping the gas lightly, the lights I would see on the Dash are Check Engine, Battery and Check Gauge and the oil pressure will drop to Zero like its not getting any Oil. In order for me to start the car again I will have to put the car in park Turn the car off and then turn it back on, the crank seems a bit longer when this happens. The stalling does not happen on long drives or short ones. On hot days if I am driving for a while I will see the Check Gauge Light flash for a moment and then back to normal. While reversing when trying to park if the engine does not cut off the engine will shake violently for about 5 secs and then its back to normal.
Could it be the power Steering Pressure switch?
I thought it was just a problem while reversing because that was the instance that it only happened, but now I really don't know Its not random It happens only in those situations.
Will post pictures and video's if requested.
Old 05-16-2019, 03:04 AM
seville009
seville009 is offline
seville009 has a good reputation on FTE.seville009 has a good reputation on FTE.seville009 has a good reputation on FTE.
Im no mechanic, but Id suspect something related to the power steering pump since its only happening on tight turns.
Old 05-16-2019, 03:10 AM
therealrift
Ok, thats a start, I was thinking along the electrical mind that there was a short in the steering column could just be a thought.
Adding to my original post from my memory, I started the Truck and turned the wheels as far as I could Left and right and would hear a decompression sound on both sides I wonder if that means anything?
Old 05-16-2019, 09:22 AM
alloro
alloro is offline
alloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud ofalloro has much to be proud of
Can you see if there are any portions of any wiring harness anywhere near any of the steering linkages that might be getting pinched?
Old 05-16-2019, 12:12 PM
therealrift
What does that require for me to take off to allow me to see this?
Ran into a person at my local market who had a similar problem he pointed me in the direction of a power steering problem like i said earlier i hear a sounds like a decompression or a light grind. ill try and get a video
Old 05-17-2019, 09:24 AM
alloro
alloro is offline
Nothing, you just crawl under the truck with a flashlight and look.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
