Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2002 Ford Escape 4wd, 3.0 front Cats
Old 05-15-2019, 08:38 PM
TBourque53
TBourque53 is offline
TBourque53 is starting off with a positive reputation.
Can anyone recommend the easiest way to remove the front cats so I can clean them out. I already replaced the rear cat and muffler
Old 05-16-2019, 05:49 AM
simonsi's Avatar
simonsi
simonsi is offline
simonsi is starting off with a positive reputation.
Front just requires unbolting after removing the Y pipe and a/f sensor in the manifold, it can then be removed by turning it around and down around the oil filter.
Rear requires removal of its a/f sensor, EGR loosening from the manifold, remove the alt and intermediate driveshaft and crossmember, then unbolt and drop down the rear of the engine.
Did both on my DILs car last fall, can do both in a day, beware breaking manifold studs on the block.
Old 05-16-2019, 05:53 AM
TBourque53
Ford Escape catalytic converters
Thank you for the info.
Old 05-18-2019, 08:26 PM
George Venier
George Venier is offline
George Venier is starting off with a positive reputation.
Originally Posted by simonsi View Post
Front just requires unbolting after removing the Y pipe .....
Rear requires ..... then unbolt and drop down the rear of the engine.
Great advice but I'm afraid it is well beyond my arthritic limitations. Is there a short cut for those not as talented as yourself? (I fear not but I had to ask!)
Thank you!
Old 05-19-2019, 05:06 PM
simonsi's Avatar
simonsi
simonsi is offline
Thank you!
Afraid, not, what I listed is all needed in order to create the room necessary to remove the rear manifold/cat assembly.
Old 05-19-2019, 05:17 PM
George Venier
Thank you Simonsi!
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
